Go to Post I am not a moderator, but I am John V-Neun. - Billfred [more]
Unread 12-01-2009, 08:35
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: 4WD Turning Difficulties
Originally Posted by ZakuAce View Post
Has anyone seriously considered a robot with two wheels in the middle as the drive wheels and having it pivot? We're thinking it would get good traction, as all the weight (well most of it) would be on the two drive wheels, and the trailer would help balance out the wheels to keep the center of gravity in the middle. Also, the simplicity factor would allow us to spend more time making a way to score.
We considred it for awhile but figured we could not use the hitch to keep us balanced and it was too risky. But we are trying to keep the CG over the rear wheels as much as possible and trying to achieve about the same thing.
Doug Leppard
Unread 12-01-2009, 11:10
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
we were thinking of using more wheels to support our robot at the front and back when it pivots. The mentors were thinking that even though the robot may be resting on an un-powered wheel at some point, the amount of force that is placed on those wheels will be negligible, as most of the force will still be on the center drive wheels. I guess it is more like the 6 wheel drive with the lowered center drive wheels, only we'll use 5 (2 drive, 2 in front on each side of our ball gatherer, and 1 in the back)
EDIT: So... the trailer hitch can never change from that height? Well that could be a problem. I suppose we could have the rear supporting wheel powered and at the same height as the main drive wheels, and have it programmed to run only when moving foreword and backword. I really want to keep the number of drive motors as low as possible.
I'll bring up this idea that was really good, but ultimately shot down because of complexity.
One of the mentors brought up an idea of a three wheeled system. it would work similar to a crab drive, but has a huge difference. The base that the wheels are attached to would be able to rotate, or rather, the robot would rotate around it. The wheels move, then the entire body moves around the base to face the direction of movement. It seemed really stable and a great way to keep the same weight distribution on all wheels, but it was rather complicated and could interfere with a ball gathering mechanism.
Unread 12-01-2009, 11:59
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
To this general topic about 4WD: I designed the wheel base to be wider than it is long, the closest being... make sure the insides of the wheels make a square. This way the wheels don't have to slip along an arc across a surface while it's turning.
http://www.linkedin.com/in/erapacki
BUZZ 175 (01, 02) - NUTRONS 125 (03, 04) - QUEEN 1975 (06)
Beantown Blitz Founder (04) - FIRST Robotics Conferences (04) - Boston Regional Volunteer Coordinator (06)
Unread 12-01-2009, 13:11
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
From the drawings of the swivel and other parts it appears that the design intent is to create a rigid attachment without freedom to rotate about the trailer wheels.
The hitch pin is a close fit. The close fit requires that the hole in the swivel have a vertical axis. The same is true for the holes in the c-channel. The 0.385 of gap is, IMHO, intended to allow for the tolerances in the height of the hitch swivel (when level) and the robot c channel (when level). I would not expect the swivel to ride much up and down on the pin. Of course I could be wrong and only testing will reveal how rigid the attachment is in practice.
Unread 12-01-2009, 21:05
ZakuAce's Avatar
AKA: Garrett
I was thinking the same thing.
Also, I talked with the mentors today, and one of them brought up a really good point. If this was illegal, in theory, then suspension could be called illegal, since it changes the height of the robot, and could potentially make the hitch higher or lower than 2-13/16 inches from the ground. So I think we're sticking with our current plan. We're only going to have the height of the drive wheels and the wheels it will pivot onto on the front and back a 1/16 of an inch or less difference.
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
