Go to Post I am also impressed that you maintained the integrity of your parentheses; you must be a software guy... - DonRotolo [more]
Unread 07-01-2009, 21:02
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
[FTC]: Reading the 12V Battery voltage in LabVIEW
Hi
I got sick of forgetting to turn on our 12V battery (for FTC) and since we can't add any sort of power indicator there's no "easy" way to allert the driver before the match starts.
Well, it turns out that the HiTechnic Motor Controller does actually measure the battery voltage and makes it available as a register.
I wrote a LabVIEW VI to read this register and convert it to milli-volts.
The cool thing is that if the battery voltage is actually OFF, then the VI returns an error. So you can detect low voltage and no-voltage.
I've written a White Paper and attached the VI along with a sample beeper program.
It's here: http://www.chiefdelphi.com/media/papers/2189
If you use it in your "disable"loop it will allert you of a problem while setting up on the field.
Phil Malone
http://www.GEARSinc.org
Unread 08-01-2009, 00:36
emmell's Avatar
emmell emmell is offline
Murphy was an Optimist!
AKA: Mannie Lowe
no team (Radbotics, RoboKnights, CircuitRunners, Oscar, and more...)
emmell is just really niceemmell is just really niceemmell is just really niceemmell is just really niceemmell is just really nice
Re: [FTC]: Reading the 12V Battery voltage in LabVIEW
What a great VI and program for all to use Phil. Thank you!
Mannie Lowe
FIRST Program Manager - Center for Mathematics and Science Education - University of Mississippi
Mississippi FIRST Tech Challenge Affiliate Partner
Unread 12-01-2009, 09:00
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
We tried this over the weekend. This is great. How in the world did you ever figure this out?
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 12-01-2009, 10:50
PhilBot's Avatar
AKA: Phil Malone
I emailed Hitechnic and asked (begged) for the register spec for the Motor Controller.
They are planning on releasing this spec. soon, but they let me see the preliminary issue. It probably helped that I'm a FRC Beta Tester, and had already been working with folks from NI and FIRST.
To be fair, I felt that everyone should benefit from what I learned.
So I created the VI and sample program.
Before you ask for a copy of the spec, I was asked not to distribute it, since it was preliminary.
Phil.
Phil Malone
Unread 12-01-2009, 11:13
The FRC community has grown accustomed to accepting that Phil does things that others can not. I believe the FTC community will soon follow.
emmell's Avatar
AKA: Mannie Lowe
Phil:
Can you turn this VI into a NXT-G block for those that are programming in that language.
Thanks,
Mannie Lowe
Unread 12-01-2009, 11:20
PhilBot's Avatar
AKA: Phil Malone
Originally Posted by emmell View Post
Phil:
Thanks,
Oh Boy.... now you're really challenging me. I've never done a NXT-G block before (certainly not one that accesses the ports directly). Is it possible to look inside the existing FTC ones to see how they work?
Phil Malone
Unread 12-01-2009, 21:13
emmell's Avatar
AKA: Mannie Lowe
Actually it might be easier than you think. Having never done LabView, I don't know what it takes, but NI was nice enough to give us manuals with the FTC install of their software. Look in their subfolder trees under the Manuals folder. There should be a PDF file called "NXT_Creating_MINDSTORMS_Blocks". It looks like it walks your through the entire process.
Thanks,
Mannie Lowe
The 8.2 (or 8.3) Battery Voltage Bug eugenebrooks Programming 167 21-02-2008 20:05
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
12V Battery Maintenance cbolin Electrical 16 27-12-2004 17:29
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Jump Start RC w/o Exide 12v battery Mark McLeod Programming 0 12-01-2004 09:15
