Go to Post Being consistently enthusiastic with a consistent message is not easy to do without sounding like a cult. We could use a reasonably large collection of things to say that restate the mission and vision of FIRST but don't appear to be stock phrases. - Alan Anderson [more]
Unread 12-01-2009, 11:49
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Picking up balls or not
One more thing to keep in mind, in 2006 the human players had a constant stream of balls at their disposal; any ball that was scored by the opposing alliiance was in the hands of the human players.
This year it's different. Each human player starts with 20 balls (or 13, depending on whether or not you want your robot to start with any. If you plan on putting balls in your robot anyway, then you will probably pre-load and start with 13). Considering how easy the shots will be right after autonomous starts, some of that ammo will likely be used up to score. If your at one of the outposts, this leaves you very few balls to last you the rest of the game.
If you are at on of the refueling stations, your stash of balls can be increased only if robots herd balls into the corner. If you need to be able to herd balls into a corner in order to get balls loaded into your machine, then why not just pick up off the floor?
new balls vs. old used up balls agndoggieboi General Forum 31 22-02-2006 14:11
ANYONE HERE NOT PICKING UP BALLS? archiver 2001 9 24-06-2002 00:08
picking up big balls archiver 2001 3 23-06-2002 22:36
How moving goal while picking up balls Matchew General Forum 14 22-01-2002 22:22
