Go to Post Go with a Big Block. The torque is awesome and you cant beat the sound of a built Big Block with a high lift cam and some open headers. A blower would be a nice addition as well. Good luck getting past the inspector. - GBK [more]
Unread 12-01-2009, 11:49
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
cRio losing connection when "run as startup"
I am trying to create a Stand-Alone application and the cRio is losing communications.
I am able to run Robot main within Labview to test the code and confirm that the robot is responding correctly. I then build the applicaton. After building, it I run deploy or "Run as Startup" from the drop-down menu I recieve the Lost Communicatons with the cRio dialog and the applications stops deploying.
I had previously been able to deploy an application as startup.
Is there something I need to check to make sure the communications are correct for the build. The laptop's IP is 10.10.94.6 (team 1094). What changes would need to be done to connect the PC directly to the cRio so that the wireless communications are taken out the equation.
Any help would be appreciated
Unread 12-01-2009, 12:09
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: cRio losing connection when "run as startup"
How long did you let it go? When I deploy a stand-alone application, I get that lost communication message, but it goes away after a while and continues. Maybe it's doing a live reboot or something?
Unread 12-01-2009, 12:18
FRC #1094
I will try and wait longer and see what happens. I know I waited about 30 sec0nds the one time.
Team 1261 - cRIO on 2008 "Longshot" Tanner Robot Showcase 2 31-12-2008 12:44
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
Will 3ds Max 2009 run on "regular" Windows XP? Kevin Thorp 3D Animation and Competition 3 12-11-2008 22:07
when are "official" results due online? Brandon Martus Regional Competitions 3 09-03-2003 08:15
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
