Go to Post Being in FIRST and putting the focus on the robot is like building a robot and putting the focus on the bandsaw (or mill or lathe, or whatever you do your machining with). The robot is a tool we use to play the game, the game is a tool we use to inspire and teach. - GeeTwo [more]
Unread 12-01-2009, 14:05
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
freely rotating bumper and hitch
Has anyone considered mounting the bumpers and trailer hitch on a freely rotating assembly such that the hitch naturally align itself in the direction the bot pulls? I wonder if it would be legal?
Unread 12-01-2009, 14:07
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: freely rotating bumper and hitch
bumpers can't articulate as of update 2 i want to say... The must be fixed to your frame
Is now an engineer thanks to FIRST.
Unread 12-01-2009, 14:11
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
right but as for the hitch it only says attached to a fixed location, well what if that fixed location's position is controlled by oh say and actuator or somethign similar
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Seems to me that if you could get the drive train (and all the rest of the guts to the bot) to rotate inside the frame, it would alleviate the situation. Just an idea.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
Unread 12-01-2009, 14:22
XXShadowXX's Avatar
They call me Cody.
Originally Posted by <R18>
The trailer Hitch must be rigidly attached to a fixed location on the ROBOT,
that should clarify some things
Originally Posted by betty_krocker View Post
right but as for the hitch it only says attached to a fixed location, well what if that fixed location's position is controlled by oh say and actuator or something similar
if you can work around <R18> part E.
Originally Posted by <R18> part E.
The Trailer Hitch must be place such that, a the TRAILER swings from side to side, the first contact between the TRAILER and ROBOT is BUMPER-to-BUMPER and not TRAILER-tongue-to-BUMPER.
which makes it a bumper issues
Originally Posted by <R08> parts G, H
E.
BUMPERS (including any fasteners and/or structures that attach them to the ROBOT) must weight no more then 18 pounds
G.
BUMPERS must attach to the robot with a rigid fastening system to form a tight, robust connection to the main ROBOT structure/frame.
H.
If a multi-part attachment system is utilized (e.g. interlocking brackets on the ROBOT and the BUMPER), then the elements permanently attached to the ROBOT will be considered part of the ROBOT, and the elements attached to the BUMPERS will be considered part of the BUMPERS.
if you can work around those rules then your in the clear. But i rather be an engineer then a lawyer, which is hard because the inspector's word is law.
Yes this would make the above statement legal (see first post), but wouldn't that really be a pain in the butt to make a rotating drive train.
Unread 12-01-2009, 14:33
AKA: Michael
sure it can be got around if all the actuator does is push partially or pull partially to shake the trailer back and forth to make scoring only than much harder
OR
you can retract the trailer in some when making turns so when it fishtails, it doesnt throw the whole system into a slide (anyone who lived up north and tows in the winter knows what i am talking about)
Unread 12-01-2009, 14:34
XXShadowXX's Avatar
They call me Cody.
OR
Fixed means not moving, in relation to the robot's structure/frame
Unread 13-01-2009, 08:36
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
It seems to me the easy way around this rule is to have the drive train connected to the outer frame (that part holding the bumpers and hitch) by some kind of turn table, rather than a rigid connection. That way the whole outer portion of your frame is rotating, and the bumpers and trailer rotate with this part of your frame.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Moving Hitch Dan2081 General Forum 5 06-01-2009 20:24
Bumper bracket and weight considerations ajlapp General Forum 26 30-09-2008 15:36
pic: Bumper and me lilac Extra Discussion 7 09-01-2008 16:22
Rotating Light - not rotating :-/ MrB Technical Discussion 17 08-02-2002 20:36
