Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
Unread 12-01-2009, 14:13
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
Fisher-price motor
I was wondering how to mount a chain sprocket or belt sprocket to the fisher price gearbox provided in the KOP?
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 12-01-2009, 14:18
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Fisher-price motor
Not easy to do, but first you have to press off the gear that came on it (be very careful, the magnets inside are fragile!) then you have a 1/8" diameter shaft you can use as you see fit. (the shaft is knurled for the gear press, but you can run he motor and press a small file against the shaft to get rid of the knurl). You can use 1/8" bore sprockets with setscrews.
Former Mentor Team 1771
Former mentor Team 4509
Unread 12-01-2009, 14:27
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I think you meant an attachment from the gearbox?
Without machining anything Try using the wheel driver found here its about 5 dollars.
http://www.householdappliance.com/power_wheels_tires.html
You want the Power Wheels Replacement Wheel Driver 74460-2249, at the bottom of the page.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-01-2009, 14:32
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
I was about to start a thread but thought this might be an ok place to ask first:
Is there a good place that you can buy a small gearbox for the Fisher-Price, maybe about 16:1. Thanks!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The inside profile of the output shaft forms an octogon. It actually took a bit of searching to find this on the forums...
http://www.chiefdelphi.com/forums/sh...hlight=gearbox
Plenty of ways to attach to anything you want.
2017 Scoring Model
CAD Library | GitHub
Unread 12-01-2009, 14:35
JesseK's Avatar
FRC #1885 (ILITE)
An AM Planetary
http://www.andymark.biz/am-0002.html
into a Stackerbox or two
http://www.andymark.biz/am-0141.html
Is about the closest you'll get to 16:1 without machining. I don't know if anyone has ever successfully mated a FP to a banebots transmission. I'm sure it's possible if you have the right machining capabilities. Then again, if you can machine it then why not just make your own, right?
2017 Scoring Model
Unread 12-01-2009, 14:41
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
There are a number of postings about using a Banebots (http://www.banebots.com) 42 mm gearbox with the F-P motor. Banebots has stopped shipping the previous version and is supposedly going to introduce an improved model - but that has been delayed.
We used these last year for our lift and it worked very well. You have to remove the pinion from the F-P motor and press on the pinion that is compatible with the banebots gearbox. The pinion used to come on the motor that came with the gearbox (RS-550 type), but you can also purchase them separately. The F-P motor has the same mounting threaded holes and shaft size as the RS545-550 motor. I just checked the site and it looks like they are about ready to make what they call the P60 available which will do this job. Comes in 4:1, 16:1, 64:1 and 256:1
Good luck.
Unread 12-01-2009, 14:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Here's the preliminary link to the new BaneBots trannies:
http://banebots.com/c/P60K-nnnn
They've a much cheaper option than the AM planetary to stacker box combo suggested above, But they're not as rugged. With only a 16:1 ratio, however, you shouldn't have any problems.
Unread 12-01-2009, 14:59
Bob Steele's Avatar
AKA: Bob Steele
Originally Posted by JesseK View Post
An AM Planetary
AS previously mentioned... the new Banebot transmission selection includes a 16:1 No machining required... and they are very easy to mount... They don't mention FP but the form factor for the FP is the "550" form factor that they discuss in the write up. The FP should interface with no problems...
I echo 2046... we used them last year with no problem at all...well at least no problem caused by the transmissions....
The new ones look even better
http://banebots.com/pc/P60K-nnnn/P60K-44-0004
Unread 13-01-2009, 12:44
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
We did this last year with mixed results. We basically made an keyed aluminum cylinder that fit inside of the octagon. We then used a hose clamp to keep the plastic teeth tight around the aluminum cylinder.
Here is our old CAD from last year, http://2008.discobots.org/node/33
If you want to see pictures, our gallery has many different pictures.
I would not suggest this approach for a drive system unless you have a more reliable way of connecting to the plastic octagon. A hose clamp eventually gets lose and then your shaft will be free-spinning.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 16-01-2009, 10:27
O-H
FRC #0048 (Delphi E.L.I.T.E.)
BaneBots P60's are now available and include free items (mounting kit, RS-545 motor, grease) with each purchase, for a limited time. See their website for further details:
http://banebots.com/pc/P60K-nnnn/P60K-4-0004
Unread 16-01-2009, 13:20
AdamHeard's Avatar
Lead Mentor
Mating a FP to a banebots gearbox doesn't *really* require machining.
First, you must break/pull off the stock FP pinion and press on the appropriate banebots one. In some cases, you must then shorten the FP output shaft.
From this point, it will mount stock to a banebots gearbox, but I would recommend a little bit of "machining" to improve them.
The motors themselves in the older gearboxes were mounted with terrible quality screws (and philips heads at that), I'd recommend replacing them with some good socket heads. In my experiences, the counterbore usually doesn't fit socket heads, so the hole must be drilled larger.
I haven't seen the inside of the new gearboxes, but they outside clearly shows the same terrible quality screws that I've grown to loathe. It's really interesting to me that they made such substantial changes to the quality, but didn't do something as simple as using decent fasteners.
EDIT: on second reading, they say socketheads are used for mounting the motor. But the screws holding the gearbox together are still not decent hex based ones.
Unread 09-02-2009, 12:12
Black Claw's Avatar
Black Claw Black Claw is offline
Eyes of the Night
AKA: Miko Wildcat
FRC #2333 (RoboSwitchEngage)
Black Claw is an unknown quantity at this point
Do you guys know if it will work for a conveyor belt?
I am the eyes of the night,
I am the whisper in the dark,
I am the shield,
I am the sword.
Unread 09-02-2009, 12:17
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It might, but it depends on the conveyor belt design...they are not all the same! One important thing when using the FP motor is to make sure the thing it is driving cannot get jammed, which could cause the motor to stall and overheat (burn up) very quickly.
If a cordless drill can run your conveyor easily, then an FP motor should be able to, if geared properly.
Unread 09-02-2009, 12:46
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
I modified one for our belt and it is fast and robust... you do need to make sure that it is running in the right direction so that the 1/4 bolt shaft tightens as it turns but this is an easy mod and works well for a one direction belt drive with an output shaft on both sides of the case...
see my posting within this link:
http://www.chiefdelphi.com/forums/sh...ad.php?t=72513
Acceleration of Fisher Price Motor Boco Gear Motors 2 06-01-2009 11:39
Fisher Price Motor Macdaddy549 Motors 5 28-04-2007 09:32
Fisher Price Motor Andrew Y. Motors 2 20-11-2006 07:52
Fisher Price Motor Mounting Ashley Weed Motors 1 16-02-2003 19:29
Fisher Price Motor .. Important! Paul Copioli Motors 7 22-01-2003 13:55
