Go to Post If I had a mul-let then I'd look like Andy Baker used to and that would be ba-ad, really ba-ad. - JaneYoung [more]
Unread 12-01-2009, 10:00
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Servo Camera Example Servos don't work
When I run the servo camera example, it works, except for the servos. It tracks and shows the servos turning on the laptop but the servos don't actually move. They are plugged into pwm1 and 2 and are shorted for servo output. The dsc is in port 4.
Any ideas why the servos aren't moving?
thanks
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 12-01-2009, 10:12
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Servo Camera Example Servos don't work
Does your DSC have power (all 3 power LEDs near the power input connector)? What's the status of the RSL (Robot Signal Light)? Is your robot enabled and in the proper mode?
Russ
Unread 12-01-2009, 10:24
Yes it does.
Wierd thing is when I do another frc project and tell the servo to go to the position of a control, it works fine. It just wont work with the camera example. I have tried turning off the smoothing also with no effect.
Unread 12-01-2009, 11:34
Should I be able to just run the examples as is from the examples folder, or do I have to put them inside a robot project? Do I have to change some settings on the DS?
Help?...
Has anyone else experienced similar problems? I actually haven't had an example work yet.
Unread 12-01-2009, 12:13
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Did you change the IP address in the project? If not, you need to set it to communicate with the cRIO. If you did, I'm not sure what the problem is.
Unread 12-01-2009, 12:36
LabVIEW or C++?
If it is LabVIEW, find where the example is controlling the servos and replace it with a control. Then you can easily command them to move.
If they move, it is the example code's fault somewhere in deciding where to go.
Otherwise, it may be wiring (which you seem to have disproven), the watchdog, opening the servo reference, communication with the DS, etc...
Also, try highlight execution mode.
Unread 12-01-2009, 18:01
Sorry for the late update, But I did get it working. The labview example didn't have the watchdog. Adding the watchdog fixed the problem. I found my answer on the FIRST forums. Thanks.
Unread 04-03-2009, 12:44
pawan89 pawan89 is offline
pawan89 is an unknown quantity at this point
Quick question. So I have been going about adapting the Two Color Servo Camera example... But where exactly is the ServoCamera.vi example everyone is mentioning? I am not able to find it anywhere
Unread 04-03-2009, 13:27
Ok so I realize most of you on a FRC team have it installed on your computers and it can be found in the /examples/FRC directory. Is that right? Would I have to go through the whole installation to extract this example as well? Or can the individual file be downloaded somewhere?
Unread 04-03-2009, 14:47
StephenB StephenB is offline
no team (Team NI)
StephenB will become famous soon enough
If you are using LabVIEW update 3.0a, the user watchdog is off by default... and if it is enabled and you run new code that has no user watchdog VIs... then it is automatically disabled.
Point being, if you opened up the code and it did not work until you added user watchdog VIs to it... you are using the wrong version of LabVIEW. Update your software: http://www.usfirst.org/community/frc....aspx?id=10934
Unread 04-03-2009, 17:09
gwytheyrn gwytheyrn is offline
AKA: David
FRC #0461 (West Side Boiler Invasion)
gwytheyrn is infamous around these parts
Send a message via AIM to gwytheyrn
You can get it here: http://usfirst.org/community/frc/content.aspx?id=10934
(Look in software updates, it's the second from bottom I think...)
alternatively, the direct link
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1215 for LV
http://first.wpi.edu/FRC/frcupdates.html for C++
Servos don't work jpflorido Programming 4 06-05-2006 06:34
How do the servos work? tml240 Motors 25 18-02-2004 07:47
Ideas that don't work. CanisLupis547 General Forum 6 13-01-2004 19:07
My sensors don't work Fares Programming 2 03-02-2003 18:26
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
