Go to Post In my book the team building experience of the kids training the engineers in the operations on the field would be invaluable. It might not get a trophy but you win far more in the long run. - Wayne C. [more]
Unread 12-01-2009, 19:23
Re: Control System Problem Help?
You can't go back to the original cRIO OTB program, but you don't really need to. You can complete your bench test using the default program that was loaded onto the cRIO when you installed the firmware update.
The behavior described by the manual will differ, but a successful bench test just makes sure that when a joystick moves at one end, a corresponding motor moves at the other end.
The cRIO reset button is just another way to reboot the cRIO, like turning it on and off, only without the power going away.
So your team number is now set on both the DS and the cRIO?
But your problem is primarily that the jaguars are blinking?
Need Help With 2009 Control System professorX FRC Control System 17 13-01-2009 20:38
Control System Update Problem tubeheaD37 FRC Control System 6 11-01-2009 20:42
So Cal Teams Control System Help ChrisH FRC Control System 5 06-01-2009 21:57
Control System wmatt2014 Control System 9 01-02-2008 09:56
control system archiver 2000 1 23-06-2002 22:04
