Go to Post There are times when your team will struggle and there are times when it will achieve great victories. There will be times when unknown and uncontrollable factors will intercede to provide an unexpected outcome for which your team must compensate. - Travis Hoffman [more]
Unread 12-01-2009, 19:17
MSecondi's Avatar
MSecondi MSecondi is offline
FRC #1254
MSecondi is an unknown quantity at this point
send labview cod to your robot?
so how do you send the code you made on labview to your robot?
Unread 12-01-2009, 19:23
Big Kid's Avatar
Big Kid Big Kid is offline
The Coach
AKA: Nick Acosta
FRC #0816 (WesTech Anomaly)
Big Kid is a jewel in the roughBig Kid is a jewel in the roughBig Kid is a jewel in the rough
Send a message via AIM to Big Kid
Re: send labview cod to your robot?
A. Have to ask is it, The FRC Robot Project file?
B. If yes, You have to go down to Build dependencies under the target and open up the tree for that.
C. Under that you should see a real-time app called FRC Robot Deployment
D. Right click ----> properties ----> Source Files
E. The only have the robot main.vi in startup
F. Add all others to Always included files
G. Hit okay
H. Right Click it again and then press build (it will take a while)
I. Once thats done Right click the RT app again and hit run on Startup
and that should do it.
Team 816
Student (2007-2011)
Mentor/Drive Coach (2013-)
Team 2495
Mentor (2016-)
Graduate Mech. Engineer at Lehigh University
Unread 12-01-2009, 21:50
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
http://www.usfirst.org/community/frc....aspx?id=10934
Check out the LabVIEW resources accessible in the above website. I would strongly encourage you to go through these tutorials to understand the syntax and get started with LabVIEW. In regards to your query, you'll specifically want to learn the difference between running an app by clicking on the run arrow on your PC and building/deploying/run as startup. You don't need to change your code at all but these have VERY different results.
Russ
Unread 12-01-2009, 23:21
MSecondi's Avatar
FRC #1254
Thanks for the quick reply and the link.
Send your name to the Moon (quickly!) dlavery NASA Discussion 5 31-07-2008 12:32
Using the IR remote to send radio commands to the robot Mikhail_Pham Control System 2 14-01-2008 00:14
Purpose of .COD file JBotAlan Programming 4 06-02-2007 16:44
SEND YOUR TEAM INFORMATION PLEASE archiver 2001 0 24-06-2002 00:34
Send me your pictures! archiver 2000 0 23-06-2002 22:02
