Go to Post Is it January yet?? - Kevin Kolodziej [more]
Unread 06-01-2009, 21:43
Logan Williams Logan Williams is offline
FRC #2192
Logan Williams is an unknown quantity at this point
How to mount rotary encoder
How do you mount the rotary encoder to read the speed of the gearbox output? I can't find any guides on usfirst.org, and it doesn't seem obvious (then again, it took me an hour to figure out how to use the Wago tool...)
Any help would be appreciated.
Thanks,
Logan Williams
Unread 06-01-2009, 23:01
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Re: How to mount rotary encoder
I'll assume you are using the toughboxes. In that case, I have an answer.
You need to either buy or make an encoder mount. AM sells them, as well as the encoders.
On the tough box, under the motor to the side, there is an extension from the output shaft. There are two holes on the sides of that, this is where you mount the mount plate to. Take a look at the mount and you should get an idea. Be careful with the spinning pattern piece (name?), as if you're not careful you can scrape the pattern right off. On an unrelated note, anyone got an extra encoder plate?
But making your own is simple, making one took me a few hours, but only because I didn't have a small enough drill bit (1/16 I think) to drill the holes for the encoder screws. I ended up swapping the bolts out for slightly larger ones and putting a bolt on the other side.
It's a hack, but that's the way we work on 1244.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 06-01-2009, 23:46
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
If AndyMark doesnt have the mounting kit you need for what you are using,
you need to fabricate your own which isn't trivial without the right tooling and expertise.
What transmission are you using? Even with the supershifters, we had to make modifications as we had some issues with a couple of them on our current practice bot.
Unread 07-01-2009, 18:45
FRC #2192
We're using the kitbot chassis with the toughboxes.
Thanks for the advice, I'll look into it.
Unread 09-01-2009, 14:30
eitang eitang is offline
Hamosad 1657
AKA: Eitan Galon
FRC #1657 (Hamosad)
eitang has a spectacular aura abouteitang has a spectacular aura about
The andymark encoder mount also requires some modifications to fit on the toughbox if i recall.
Unread 09-01-2009, 17:54
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
I think Beach Bots uses surgical tubing that is zip tied to the output shaft and encoder shaft. That way if it isn't lined up perfectly, the encoder doesn't get ruined.
Ryan
2010 Los Angeles Finalists
2010 San Diego Regional Winners
2009 Los Angeles Regional Finalists
2008 San Diego Regional Winners
2008 FTC World Champions
Unread 09-01-2009, 20:29
guitargoddsjm guitargoddsjm is offline
FRC #0467 (The Duct Tape Bandits)
Team Role: Electrical
guitargoddsjm is an unknown quantity at this point
Send a message via AIM to guitargoddsjm
What's the distance between the center of the two holes on the mount?
Unread 09-01-2009, 22:38
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
OK, I know those adapter plates were only $3, but they cause at least $50 of grief each.
First the plate hits the motor so you need to shave it, then the two holes that mount the encoder itself are just a bit off, so you end up using a LARGE amount of force to mount a fragile optical encoder circuit. Basically none of the critical dimensions are up to par.
JMHO
Based on my FTC experiences, the wires for the encoder (on the cable) are also extremely fragile. So mount and protect them well.
Phil Malone
http://www.GEARSinc.org
Unread 12-01-2009, 15:39
bluegrasscoder bluegrasscoder is offline
FRC #2436 (Bearacudas)
bluegrasscoder is an unknown quantity at this point
How do you terminate the wires coming from the encoder? They are unterminated in the kit. Is there some sort of PWM female connector kit that is available?
Also, where can we get the spec sheet for the encoder, I couldn't find it on the competition manual.
Alan
Unread 12-01-2009, 16:05
ok, so I'll partially answer my own question. I found the spec sheet here:
http://www.usdigital.com/products/en...rotary/kit/e4p
this is all based on the AEDR, spec sheet here:
http://www.usdigital.com/products/aedr/
So, I get "what" it is, so how do I use it? It's got two channels of output which allow you to tell if you are going clockwise or counterclockwise by comparing the outputs. Can you do this on the cRIO or do you need something else to do the processing? Do you have to make your own splitter cable for this?
Thanks in advance.
Alan
Unread 12-01-2009, 16:18
Sorry, I'm an idiot -
http://www.chiefdelphi.com/forums/sh...ad.php?t=71559
This thread shows how to hook things up.
Alan
Unread 12-01-2009, 16:25
AdamHeard's Avatar
Lead Mentor
Ryan
While not the same type of encoder that is mentioned here, this method is AWESOME. I've seen them (Well, they technically use POTS) be literally 30 degrees out of alignment, I'm not talking parallel shafts that weren't concentric, I mean shafts pointing different directions. They still worked.
Unread 12-01-2009, 16:43
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
That surgical tubing trick sounds awesome!
By the way, if anyone a Drawing with dimensions in order to make a custom mounting plate, just contact me.
thanks, Vivek
"we don't build robots, we build people"
Unread 12-01-2009, 20:00
dnklat90 dnklat90 is offline
Student Software Leader
AKA: Dan 2
FRC #2338 (Gear it Forward)
dnklat90 is an unknown quantity at this point
Send a message via AIM to dnklat90
thanks, Vivek
Are you looking for the drawings or is it that you are giving the drawings away?
Thanks, Dan
HELP US BANEBOTS 56mm Gearbox Mount Encoder bhenry677 Electrical 3 05-09-2008 13:47
pic: Rotary Encoder Mount Madison Extra Discussion 8 10-03-2008 21:44
Rotary Encoder Collars team222badbrad Technical Discussion 1 09-11-2005 19:14
Rotary Encoder (optical etc.) Gary C Technical Discussion 4 16-01-2005 18:23
How does the rotary actuator work? kvzrock Pneumatics 10 26-01-2004 22:32
