Go to Post "Why use a CNC when you can get it done with wood, duct tape, and zipties!" - gcgeobuff [more]
Unread 12-01-2009, 20:03
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
Sorting 2-D Arrays [Labview]
I spent about 3 hours today circumventing the idea of sorting 2-D arrays in Labview. I had a 2-D array of 3 values. My plan was to reorder the array by one of the values while keeping the other values in the same index.
For example, this array:
[0] 6 14 28
[1] 7 81 4
[2] 1 15 38
I would want to sort it by column 3 making it this:
[0] 7 81 4
[1] 6 14 28
[2] 1 15 38
Does anyone know of a simple way to do this, or should I stick with my excessive, hard-to-follow code that I don't think I'll ever understand now that I've finished writing it?
Unread 12-01-2009, 20:10
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Sorting 2-D Arrays [Labview]
With only three elements, it may be enough to avoid "sorting" sorting altogether, and just use a few IF statements. Not practical for larger sorts, but it might be best in this case.
Unread 12-01-2009, 21:21
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
have you considered storing the 2d array as a 1-d array of clusters? that way you could store the item you want to sort by in the first slot and just do a 1-d built in sort.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 12-01-2009, 21:28
FRC #1379
As a matter of fact, I just got the same response from one of our mentors (aka my brother) and it's working perfectly.
Thanks.
Unread 12-01-2009, 21:58
Unfortunately, there is no easy way to tell LV exactly how to sort more complicated data containers. LV deals with almost any type, but only 1D containers, sorted by first, then second, etc, and only in ascending order.
The attached snippet shows how to build an index array, then rebuild the 2D array based upon the indices.
Greg McKaskle
2008 Match Sorting Algorithm Grant Cox Rules/Strategy 1 09-01-2008 21:41
Sorting out Digital NASA TV Billfred General Forum 2 03-12-2007 18:55
pic: Sorting drill bits Andy Baker Extra Discussion 12 16-02-2005 21:46
Arrays on the PIC? scitobor 617 Programming 8 06-12-2004 09:10
EduCAD and Arrays!!!!! Sachiel7 Programming 14 03-11-2003 03:21
