Go to Post Didn't know the details about the battery. In the past it was just a black (grey) box with two terminals...use...recharge...use..recharge. - cbolin [more]
Unread 12-01-2009, 19:33
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Floor wearing away
I was doing some traction tests with a stationary robot (measuring the pull of the robot at different drive speeds). I noticed about halfway through that there was a smell of urine with a hint of burning plastic. Upon closer inspection, I found the regalith to be wearing away, leaving small piles of dust. It had by no means worn flat, but the fact that the floor wears away before the wheels worries me for two reasons:
1. Regalith is a fiberglass composite. That effectively means it leaves fiberglass dust when it wears away. I handle fiberglass almost as carefully as I handle asbestos (that is, not at all, whenever possible).
2. At the arena, the robots all start in approximately the same position. If a majority of the robots start by spinning out as fast as possible to gain the most traction, these starting positions will soon have small piles of dust there, affecting both the air quality and the traction (or lack thereof).
I was finding that, as I sped up the drivetrain, the traction oscillated between 10lbs and an increasingly higher pull (20lbs when I stopped). I hypothesize that if the floor did not wear, then the traction would have remained at a little less than 10lbs, however, I have neither the funds nor approval for continued destructive testing.
-- Marshal Horn
Unread 12-01-2009, 19:48
WhiteShadow1474's Avatar
WhiteShadow1474 WhiteShadow1474 is offline
FIRST. Much better than SECOND.
AKA: Jason
FRC #1474 (Master Link Militia)
Team Role: Student
WhiteShadow1474 is an unknown quantity at this point
Re: Floor wearing away
That's interesting. I'm sure FIRST must have tested this before. Maybe they add something that doesn't affect the coefficient of friction but reserves the playing field's condition
Poor minds discuss gossip. Brilliant minds discuss ideas.
Unread 12-01-2009, 20:05
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Floor wearing away
Greatest traction is achieved when starting out by applying torque to the point just before wheel slip (Dynamic vs. Static Friction). If you are burning out at start, you are not going anywhere if the surface is intact. I suspect your traction increase may be due to the material the rogolith is adhered to is being worn through. It may have a higher CoF than the surface film. FIRST may have to clean these areas between matches, and may even have to replace sheets in these areas if it truly is a problem. It will be something to watch for while we are testing, and report to FIRST as a potential problem. Everyone should take note, and Thanks or the observation.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 12-01-2009, 20:13
Bob Steele's Avatar
AKA: Bob Steele
These spots will be very hard to replace individually because the official playing fields are made of three 8 X 50 foot rolls of this material and not individual sheets that we are using.
this could be a problem... I am not as worried about the damage to the field as much as I am worried about the potential of fiberglass dust to be in the air around the fields...
I would not think it would be very much...but it does not take much.
Unread 12-01-2009, 20:47
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Hey, we just did our first test woth the robot today, we put some weight on to make about 120 lbs, and we found dust on the wheels. I think the wheels were picking up the dust created by the floor. And we also found that the dust that stuck to the wheels, and greatly decreased the traction.
Unread 12-01-2009, 20:54
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
No one's worried about the urine smell he described?... I can take dust, i can take a worn out launch area....I'm sick of urine...... don't ask
TEAM 549
Unread 13-01-2009, 00:05
OScubed's Avatar
OScubed OScubed is offline
Lee Drake, CEO, OS-Cubed Inc.
AKA: Lee Drake
FRC #1511 (Rolling Thunder)
Team Role: Parent
OScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond repute
Send a message via ICQ to OScubed Send a message via AIM to OScubed Send a message via MSN to OScubed
Some links for FIRST Safety to peruse from the CDC:
http://www.cdc.gov/elcosh/docs/d0200...7/d000257.html
Does anyone have an MSDS for the regolith?
Lee Drake, CEO, OS-Cubed, Inc.
Business Mentor - team 1511
Rochester, NY
Building optimal, stable, secure solutions to your business challenges.
Unread 13-01-2009, 01:18
AKA: Dr. Brooks
no team (WRRF)
Dust from wear is probably the biggest reason to not allow
vacuum effect robots, as these would suck the dust from the
floor and pump it into the air. It may be a good idea for the
field to be equipped with a HEPA vacuum, or some other dust
collector, to clean the plastic surface when needed.
Eugene
Unread 13-01-2009, 07:01
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Wasn't regolith a gel coated frp? Maybe the gel is to stop that?
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 13-01-2009, 07:25
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
Totally agree...I'm kind of surprised that they wouldn't mention their special "mixture" (giving them the benefit of the doubt)
that light is NOT yellow, its orange! Where is the yellow light?
:1..2...3...BEAST!:
Unread 13-01-2009, 07:34
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Marshal:
You are not alone with your concerns and results. We experienced that same thing the first time we tested the robot. We immediately stopped when we started to smell the burning plastic.
Houston we have a problem.
To make matters worst, I'm fearful of using our hallways or gym. Any sharp turning or spinning and the robot leaves marks in the wax finish. I can not afford to make enemies with the custodial staff.
We went out and sacrificed another $150 in FRP in an attempt spread out the damage and safety risk
Anyone have any idea what to do with this material after the season?
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 13-01-2009, 07:37
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Originally Posted by Sunshine View Post
Marshal:
This is why you keep some extra snacks and soda around to give to the janitors. Bribing them can't hurt
Unread 13-01-2009, 08:37
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Are you sure the powder isn't coming off the wheels? We did a weighted test this weekend in our gym and noticed that for the one drive we did with weight on the bot, it left big white streaks across the tan/brown gym floor. When we wiped the streak, we were left with very fine white powder, leaving us to conclude it was the wheels, and not the gym floor, that was the source.
Unread 13-01-2009, 08:44
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
Attached is the only one I had found, from a supplier's website.
http://www.sbs-frp.com/products.htm
MOE 2007 Chairman's Video by MOE video team and Paul Lazarus http://moe365.org/CHMN_AWD_video_2008.php
MOE 10-Year Video Celebration on YouTube http://www.youtube.com/watch?v=ETcSMUBUqEs
Unread 13-01-2009, 09:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The only markings left on our Regolith after testing (particularly the sideways push) were black marks. The black marks won't come off and I believe are the wear of the field. I noticed the wheels themselves had some scratches them, and had a fine powder of something on them. I cleaned them before I investigated it.
GitHub
Floor Problems Lucario231 General Forum 14 09-01-2009 07:28
Wearing You Schools Colors Benefits RIT_FIRST_LH Team Organization 21 05-04-2008 18:38
drive train wearing out? gurellia53 Technical Discussion 29 31-03-2008 08:48
Senior Prom 2005, what are you wearing? Kyle Chit-Chat 21 26-05-2005 12:35
pic: Team 1657's goggle-wearing Tomato Yov Extra Discussion 7 17-12-2004 12:06
