Go to Post Chief Delphi down for a few hours ON A WEEKEND??? This is MADNESS! - [more]
  #166   Spotlight this post!
Unread 08-01-2009, 01:48
repairmanray repairmanray is offline
repairmanray can only hope to improve
Re: How can we drive on this new floor?
Originally Posted by pacoliketaco View Post
if you ask me, we dont have to have the wheels spinning in a circular orbit. by building a hub that allows the rotation of the wheel to be offset from the center, a different driving stlye would result. im not sure if this would help at all, or be legal for that matter, it just seemed interesting.
Kind of like bouncing on the bumper of a truck stuck in mud? Interesting idea.
  #167   Spotlight this post!
Unread 08-01-2009, 02:16
jab0ii jab0ii is offline
FRC #0846
jab0ii will become famous soon enough
WildStangs removed the vid. because they are not willing to share their results of the test.
  #168   Spotlight this post!
Unread 08-01-2009, 03:08
CraigHickman
Posts: n/a
And this knowledge is proven/justified how...? Baseless assumptions aren't good. I'm sure there was a good reason for them to remove it. Whatever it is, it's pointless to speculate until we're told.
That being said: Teams that think in the boxes that we've gotten used to over the last few years WILL fail. I'm willing to bet on it. A standard skid-steer robot will be weighed down and messed up by the trailer. Only robots with specifically designed steering and control mechanisms will be able to move around with enough speed and control to make themselves useful on a strong, competitive level. Just ask anyone who's driven up here in the north about how to drive on Ice, and you might learn some good tips on how to control your bot.
  #169   Spotlight this post!
Unread 12-01-2009, 21:04
Dracco1993's Avatar
Dracco1993 Dracco1993 is offline
AKA: Jordan Miller
FRC #1741 (Red Alert Robotics)
Dracco1993 is an unknown quantity at this point
Originally Posted by jager1976 View Post
I'd be interested in where this rule is. <R06> says "The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). The ground being a plane, this seems to suggest that the wheels may be angled. Maybe?
The wheels can not be angled as you are talking about.
Jordan Miller
___________________________________________
2010 Dean's List Semi-Finalist, Boilermkaer Regional
FRC 1741 --- Mentor
Vex 323a --- Mentor
  #170   Spotlight this post!
Unread 12-01-2009, 21:07
Dracco1993's Avatar
AKA: Jordan Miller
As we have found out in tests, it is better to go to full power right away thatn try to slowly speed things up, since kenitic and static friction are so close to each other that it makes no diffrence but it is easier for the drivers to control.
Jordan Miller
FRC 1741 --- Mentor
Vex 323a --- Mentor
  #171   Spotlight this post!
Unread 12-01-2009, 22:21
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Hmm, your tests seem to disagree with ours...
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
  #172   Spotlight this post!
Unread 13-01-2009, 07:54
GaryVoshol's Avatar
Cogito ergo arbitro
The axle going through the wheel can point north, south, east or west, or any spot in between the cardinal directions. The axle cannot point at an up or down angle.
(since 2004)
  #173   Spotlight this post!
Unread 13-01-2009, 15:54
Einstein Einstein is offline
Einstein is an unknown quantity at this point
WHEELS WHEELS AND MORE WHEELS. Not in line wheels but hub to hub to hub wheels. like a 16 to 20 wheel drive. all wheels drive all wheels have friction. You need as much surface on the ground as you can to get more friction. ie you have a car with the right inflation on all the tires you get the best gas per mile.
they always tell you to check you tire pressure. now let out 10 lbs what happens to you gas mileage (it goes down right) you did not change the weight of the car you just changed how much surface hit the ground which in turned gave you more friction. and that is what you need more surface to hit the ground. the weigh divided over the wheels don't matter the bot still stays the same weight
  #174   Spotlight this post!
Unread 13-01-2009, 17:40
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Simply put, this is incorrect. The friction force is equal to the normal force times the coefficient of friction. This has already been discussed numerous times. Increasing surface area on an ideal surface will never increase the friction.
Mentor 2415
  #175   Spotlight this post!
Unread 13-01-2009, 23:18
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
We found out a few interesting things today. we mounted 4 of the rover wheels on the back of our 2008 lowered center 6wd and drove it on the FRP. the weight is biased pretty far back so the front never touched down. right away you could push it around really easy like they did at the kickoff. after wearing out a few batteries driving around, the wheels got a a significant amount more traction. we then put a small scale in front of the front bumper and told the driver to push as hard as he could without spinning. it pushed with about 35 lbs of force until the wheels broke loose, when the scale went down to about 19 lbs.
This type of drivetrain (long 6wd, lowered center) drives like a smaller version of a wide robot as long as it stays on the rear 4 wheels turning was pretty easy but we haven't hooked up a trailer yet.
2016 Central Illinois Winner. Curie Division finalist
  #176   Spotlight this post!
Unread 14-01-2009, 04:46
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
our team had an awesome idea!!!!!! we are gunna use a high speed fan to create traction because the fan will wanna stick to the regolith when air is being sucked in haha
  #177   Spotlight this post!
Unread 14-01-2009, 04:49
jsasaki's Avatar
AKA: Jun Sasaki
1 more thing i forgot have an awesome 2009 and good luck
  #178   Spotlight this post!
Unread 14-01-2009, 06:34
AKA: Sean
This has been deemed illegal by the GDC. Any method of increasing traction is illegal this year, which would include attempts at increasing your normal force.
Mentor 2415
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
