Go to Post Sometimes, it takes years to gain respect and to learn to understand the opportunities that avail themselves to those who pay attention, are willing to learn from the best, and dig deeper into understanding what it means to be a competitive FRC team. - JaneYoung [more]
Unread 12-01-2009, 18:21
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Question Fisher Price Gearbox?
I saw a few threads on this, but none really answerd my question. First, is it allowed to modify these, and second, how do I do it? Could you give me a link to specific instructions? Thanks alot.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 12-01-2009, 18:29
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Fisher Price Gearbox?
I believe you are allowed to modify the gearbox since it is not considered integral. We can't really answer your question on how to modify it since you have not described what you wish to achieve.
Please elaborate.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-01-2009, 18:39
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Sorry, I should have specified. I want to increase the output speed. I'm not quite sure how much though, so if there are several ways of doing it, then you can just show me what you know. Thanks.
Unread 12-01-2009, 18:51
Imaginary Friend
AKA: Kevin Li
Team Role: Student
If it's not by much I would use a sprocket to step up the speed. I can't think of a good way to modify those gearboxes for that purpose. You can open up the gearbox if you want to take a look inside.
I would also try http://banebots.com/pc/P60K-nnnn/P60K-44-0004 or picking another one from andymark.
Kevin Li
596 - Sciclones
Unread 12-01-2009, 19:24
Yeah... you can modify the FP gearbox, as it isn't integral.
However, it might not be worth it. The FP goes 15000 RPM free speed (give or take a few hundred or so), and I'm trying to remember what that gearbox takes it down to. If it's close to the gearbox number, use a sprocket or two; otherwise, use a different gearbox.
Unread 12-01-2009, 19:37
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
I think the F-P gearbox is 124:1. Pretty slow. Works for arms (like 330 has done with it). As was pointed out, there are a couple of other options for using the F-P motor, and which mount more easily. The kidney bean shape of the F-P gearbox takes some creative mounting work, and you still have to make something to couple onto a shaft (usually).
Unread 12-01-2009, 19:52
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Fisher Price Gearbox?
The Fisher Price motors will mount on planetary transmissions available from Banebots.com in various output speeds. We have also used the plastic gears mounted between plates to create a transmission, and have abandoned the plastic housings. To speed it up, we have eliminated one or two spur gear stages. They will hold up well if you don't put them into an application that will stall the motors. You will need a milling machine to bore the plates to mount the gear shafts the proper distances apart.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 12-01-2009, 19:56
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Our team did that in two places on the 2006 Championship bot. It's sitting here beside me, and all I know is they hacked off the output gear and the body around it, and jacked a shaft into what looks to be the next-to-output gear. I asked one of the 2006 team members about it (before my time) and he said it was a pain, but it's still working. Good to have some spares to practice with, but don't be afraid to open one up and take a look.
Mounting the gear box ordinarily can be quite simple. Run a shaft through the hole (supports the weight) and any bar with a screw or two through the plastic to take the torque.
Good luck!
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 12-01-2009, 20:02
330 uses two further reductions for arms.
15000/124= 120 RPM output speed, roughly. What speed are you looking for (roughly)?
Unread 12-01-2009, 21:05
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
about 600 rpm.
Unread 12-01-2009, 21:14
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I would probably go with a couple 25 pitch sprockets to increase the speed. My second option would be to get another gearbox.
Kevin Li
596 - Sciclones
Fisher Price Gearbox nreynolds General Forum 23 22-01-2008 13:18
Fisher Price Gearbox Model? AdamHeard Inventor 1 12-01-2007 05:56
Fisher-Price Gearbox? Aaron Motors 4 17-02-2004 17:41
Fisher Price gearbox Manoel Motors 0 14-02-2003 16:06
Fisher Price Gearbox Q... Anton Abaya Motors 17 27-01-2002 08:39
