Re: Gearboxes for shooter?
we're using a CIM on a 9:1 Banebots planetary. Gives us more torque so the wheel doesn't slow down as much as each ball goes through, and still keeps a hefty RPM on the wheel. Also theres the added benefit of really easy direct mounting since the output shaft is a simple 1/2" OD with a 1/8" keyway. Though we are actually going to use a sprocket combination with it to give the possibility of high torque or high RPM based on what our testing shows.
using a hub?
we have the 12:1 BB's but there kinda slow... |
| motor for ball Shooter? | excel2474 | Motors | 42 | 15-01-2009 09:48 |
| which gearboxes can we use for this year? | mahmosh | Kit & Additional Hardware | 2 | 09-01-2009 19:52 |
| Which pinions for FP motors and BaneBots 42 mm gearboxes? | Madison | Technical Discussion | 3 | 23-01-2007 20:04 |
| Speed Sensor for Ball Shooter | Justin Stiltner | Electrical | 15 | 28-01-2006 14:40 |
