Go to Post We've done all the speculation we can do (some of us with less knowledge than others); let's rest our minds and keyboards and wait. - Astrokid248 [more]
Unread 12-01-2009, 23:37
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
Saving images/video from camera (LabVIEW)
I want to be able to be able to take screenshots and save video from the webcam, so I created screenshot and video vi's using the IMAQ functions.
The screenshot vi was tested on my computer first, so I know it works correctly.
The problem is, when I place this screenshot vi in the robot code and try to take a screenshot, I can see the filename and picture of the supposedly saved image and using probes and no error is generated, but no image is actually saved.
Is it possible to save images/video in this way, or will I have to incorporate these functions into a dashboard project which runs on the computer rather than the robot?
On a somewhat related note, is there a simple way to write data the cRIO's onboard storage? I haven't found any functions related to data storage on the cRIO itself, but I may be looking in the wrong place. (I could also have found them, but not realized what they are for.)
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Unread 13-01-2009, 09:04
Re: Saving images/video from camera (LabVIEW)
The cRIO onboard flash is accessible using file I/O. This should be true of reading text scripts, or saving images. To get an idea of what the disk of the cRIO looks like, ftp to it. If you do more than look, you may have to reimage...
Greg McKaskle
Unread 14-01-2009, 10:50
Joel Spadin
Thanks for the tip.
For some reason, the IMAQ write function does not work on the robot. I had it set up to organize screenshots into directories by date though, and I can see the directories where it would have saved a screenshot had it worked.
Taking screenshots and video from the dashboard works normally, though I must have the timing loop for the video set up wrongly because, though it should be adding 10 frames a second to an avi set at 10 fps, the resulting video goes looks like the fast-forward button is held down.
2008 Judges' Award
Unread 16-08-2010, 16:21
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
FYI The Imaq and Imaq dx Vision bundle were not originally able to function on the cRIO. In June of 2010 Labview released an update for which gave that capability. You can expect it to appear in the 2011 competition code.
Programing is the real way to build a robot.
New Video Blog Entry: "Video from Live LabVIEW Session for FRC Competitors in Toronto LVMastery NI LabVIEW 0 13-12-2008 08:09
Inventor images from Industry pmax Inventor 0 08-01-2007 19:20
pic: Images from Bash #2 JohnBoucher Extra Discussion 1 09-10-2005 13:41
Capturing Video from camera with Premiere 5.5 sanddrag IT / Communications 14 09-09-2005 04:45
Saving sound in an AVI from max? Kevin Thorp 3D Animation and Competition 1 11-02-2005 13:21
