Go to Post Mmmmm, First Choice day. I can already taste the latency. - ttldomination [more]
Unread 13-01-2009, 00:09
Trailer hitch rules contradiction?
Originally Posted by <R18> part D
The Trailer Hitch must be located on the BUMPER PERIMETER of the ROBOT structure such that it may easily connect with the tongue of the TRAILER (attached to the TRAILER).
Originally Posted by GDC
Any hardware used to mount the Trailer Hitch is considered part of the ROBOT and not the Trailer Hitch. As such, it must be weighed and volume-checked with the ROBOT.
(http://forums.usfirst.org/showpost.p...58&postcount=2)
How do we attach the Trailer Hitch on the BUMPER PERIMETER using hardware that must remain inside the BUMPER PERIMETER? I can't see any way to follow the rule and meet the requirement in this GDC answer. Before I submit my own question officially, I wanted to find out if I was overlooking something that others see as an obvious option.
Unread 13-01-2009, 00:11
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: Trailer hitch rules contradiction?
My guess would be that these connection devices only are considered for weight constrictions not volume constrictions.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 13-01-2009, 00:48
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
I do not think you are overlooking anything. Drawing GE-09040 shows an example of how the trailer hitch should be attached using bolts that are at least 1.25 in long. Since the bolts have to be removed during the inspection process to weigh the robot with out the trailer hitch, I think the GDC assumes that you will not attach the bolts to the robot during the inspection process and instead will just weigh them with the rest of the robot. I think this is a simple case of the GDC assuming that anything that counts in the weight of the robot must count in the volume of the robot and not catching this obvious exception. I would submit the question.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 13-01-2009, 07:34
GaryVoshol's Avatar
Cogito ergo arbitro
I saw that too. I think it's going to be like bumper attachments. (Going back to old rules ...) bumpers were commonly attached via a bolt on the bumper going through the frame, held on by a nut. How many teams threw a handful of nuts onto the scale with the robot?
The ruling is consistent with previous rules. If the application of the rule by inspectors is consistent with previous inspections, the spirit of the rule will be met but the letter will not.
Go ahead and ask. But like any good lawyer will tell you, you don't ask a question you don't want to hear the answer of. Oh sorry, we're not supposed to lawyer the rules. Strike that last comment from the record and instruct the jury to disregard it.
(since 2004)
Unread 13-01-2009, 08:00
To add insult to injury, size must be checked without the hitch. Either the inspection box will allow it or the hitch will have to be removed for inspection. Watch for an update on this one.
Unread 13-01-2009, 10:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Eesh, we just finished the frame design in CAD last night. It has a fiberglass panel as the back bumper perimeter, and then the steel hitch spacer and c-channel hitch mount went outside of that. The intent is for it to be removed via bolts during inspection.
Hopefully that update comes by Friday, as the original plan was to weld the frame next week. ^
GitHub
Unread 13-01-2009, 11:27
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
No, GDC put on the Q&A:
The specific method for mounting the Trailer Hitch to the ROBOT is left to the TEAM to decide, based on the particulars of their design. Note however, that an inadequate design that is not robust enough to keep the TRAILER attached to the ROBOT will result in a violation of Rule <G35>.
Unread 24-01-2009, 17:41
FRC1672's Avatar
FRC1672 FRC1672 is offline
Team 1672
FRC #1672 (Mahwah Robo T-Birds)
FRC1672 is on a distinguished road
so the mounting IE the 7 inch bar along the robot is included. But is the actual swivel icluded
Unread 24-01-2009, 18:27
Ummm.... what?
The Trailer Hitch is the 7" C-channel and the 7" spacer bar. Neither is included in the weight/volume.
And, to answer the original question, according to the Q&A, the hardware will be weighed and then checked individually to see if it adds volume.
Trailer Hitch ewyllie59 Technical Discussion 8 24-01-2009 15:00
Trailer Pin Hitch Magnechu Technical Discussion 11 10-01-2009 00:56
Trailer Hitch Location geekofband007 Rules/Strategy 6 06-01-2009 19:46
Trailer Hitch ewyllie59 General Forum 7 06-01-2009 08:33
