Go to Post There is a fine line between genius and insanity, watch your step! - Al Skierkiewicz [more]
Unread 13-01-2009, 00:41
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Laptop Controlling a Motor
I was wondering if anyone knew how to make a laptop control a motor but not like in LV front panel using some sliders and stuff.... I'm talking about using keyboard keys to run a motor forward/reverse. (eg When i hold "E" it goes full forward and when i hold "D" it goes full reverse)
Is this possible?
I have been playing around quite a bit in LV and i can't seem to find a function that would do this... Perhaps i overlooked something?!
Thanks!
Unread 13-01-2009, 03:18
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: Laptop Controlling a Motor
I'm no programmer, but I think in therory you could use a keyboard as a input device with just the USB ports.
Tell me how it goes.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 13-01-2009, 04:39
dgraves702 dgraves702 is offline
FRC #0702 (Bagel Bytes)
dgraves702 is an unknown quantity at this point
Event Structures in LabVIEW can be used to recognize if a button is pressed, but I'm not sure what other effects using the Event Structure will have on the rest of your program.
Unread 13-01-2009, 08:56
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
you could have a slider from 176 to 255 on your front page that would be directly tied to the motor out put, but you would have to go past a lot of case structure to get to it possible i think, but time consuming.
Is now an engineer thanks to FIRST.
Unread 08-02-2009, 14:16
Tach'ko's Avatar
Tach'ko Tach'ko is offline
Vice President of the planet Earth.
AKA: Jeffrey
FRC #2344 (Saunders Droid Factory)
Team Role: Electrical
Tach'ko is an unknown quantity at this point
If you make a VI separate from a robotics project, Labview does have functions to get keyboard, mouse and joystick values. However, these seem to be disabled in FRC projects, leading me to believe that they don't want us doing that... I can't imagine why though.
Not sure how old this thread is, it was pretty far back, so I don't know if I'm violating any thread necromancy rules. Sorry if I am.
If anybody understands the meaning of Webber T, let me know. I think my teacher made it up...
I'm bored... Check out mai devArt!
Controlling motor speed WGRAY Programming 9 16-02-2009 22:50
Controlling team 803 Programming 10 21-02-2006 13:56
Controlling motors railerobotics Programming 6 17-01-2006 17:17
Problem controlling a servo Entropia Programming 2 18-06-2005 18:36
