Go to Post But altering register values via bitwise operations in nested ternary commands is so much fun! - artdutra04 [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 13-01-2009, 03:01
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Inconsistent reading from encoder get rate
I have been getting inconsistent reading for rate from the encoder get VI. The distance is good, but the rate will alternate between multiple values. The values are different depending on the Mode (1X, 2X, or 4X). I thought it was a difference between makes of encoders. It turns out that there is a LV problem that NI tech support has been able to reproduce. See my thread: http://forums.usfirst.org/showthread.php?t=11004
Does reading from the serial port work? Alan Anderson Programming 16 29-01-2008 07:15
Reading NES controller from digital inputs bear24rw Programming 10 07-04-2007 01:17
Reading Pan Angle from terminal.c marccenter Programming 3 09-02-2007 14:58
Reading an encoder with interrupts GlennGraham FIRST Tech Challenge 4 25-08-2006 12:44
reading negative numbers from a file in VB complete Programming 4 27-12-2005 19:24
