Go to Post Add a little more grease if you aren't sure exactly how much you need. - MrForbes [more]
Unread 13-01-2009, 06:06
Nimrod Beker Nimrod Beker is offline
Thunder-Bolts Porgramming Team
FRC #2630 (Thunder-Bolts)
Nimrod Beker is an unknown quantity at this point
Re: More than boolean Case Structure...
Well first of all, great thanks kevin for trying to help.
I didnt really understood what should i do..
your idea sound very well, but one problem, buttons are boolean (by the way i could not find the "boolean array" over labview, so please, if you can to write where it is ) and as they are boolean, they're value will equal, so it will not be able to recognize which button pressed, plz correct me if i made a mistake..
i need a thing that some-how know to work like if\else in C's different languages.
something that work like this
"button 1 has been press so ill enter case 5. now button 3 and 7 pressed together, this would enter to case 4"
ill hope my little example will help you to help me better
Great thanks for you kevin and for every one that can help me to solve my desire lol
Nimrod Beker, Programming Team, Thunder-Bolts.
CRio more than nationals lenny8 FRC Control System 6 16-11-2008 12:33
More than One Regional? smurfgirl Regional Competitions 35 26-03-2008 14:21
More than 1 autonomos... Jimmy_Team7011 Programming 5 16-03-2008 15:33
more than 4 ir controls? Vanquish Programming 2 12-01-2008 14:52
Robowarriors: More visited than CD! Tim Arnold General Forum 11 26-10-2007 11:54
