Re: Motor speed sensing with the Jaguar motor controller?
Digging into the LabVIEW code, it appears that the Set Speed and Get Speed VIs just end up setting and retrieving the PWM output value (0..255) by way of a speed value (-1..1). By default, the VIs assume the motor's speed is linear from 0 to 255. If it isn't linear, you can specify your own VI to do the transformation.
So, there is no speed feedback from the Jaguar at this time. It is possible that speed will be available over the CAN bus in the future, but I don't know. |
The Jaguars have the capability to report the amount of electric current being drawn by the motors (but this does not give you direct information about the actual speed of the motors) over their CAN bus interface; this interface is illegal for FRC this year. If you want to know the motor speed, try using the US Digital encoders included in the KoP. These have an API in LabVIEW that will automatically track speed, as well as distance traveled and direction of movement if both sides of the quadrature encoder are wired. The encoders get connected to two digital inputs on the Sidecar: Wire the Brown, Red, and Blue wires to the Ground (black), +5 (red), and Signal (white/yellow) wires of one PWM cable, respectively, and the Yellow wire to the Signal wire of a second PWM cable.
--Ryan Last edited by RyanCahoon : 13-01-2009 at 16:56. |
Which rule states that we can't get use the Jaguars interface? I am under the impression you are able to use it...
| Jaguar Motor Controller Problem | prashil27 | Electrical | 5 | 07-01-2009 21:21 |
| are we allowed to control a window motor using a speed controller? | Wstedtlogan | Motors | 1 | 19-02-2006 15:47 |
| <R86> No more than one motor may be connected to each speed controller. | Michael Hill | Electrical | 2 | 08-01-2006 02:00 |
| Drill Motor/Speed Controller/Who Knows What Issues | GMitchell | Motors | 12 | 28-01-2003 17:11 |
| What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. | Robb Gerber | Motors | 2 | 23-01-2002 08:58 |
