Go to Post We draw the line when our students are more affectionate towards the tools rather than eachother. - ksafin [more]
Unread 13-01-2009, 16:53
jkjohnson jkjohnson is offline
AKA: jasmin johnson
FRC #1748 (Lab Rats)
jkjohnson is an unknown quantity at this point
Need help in c++ and windriver
Im new to programming in c++ and using the windriver enviornment. I was wondering if any one could post example drivecode (I read the simple robot code and it did not work when I downloaded it).
ThanK you in advance!!!
Unread 13-01-2009, 17:27
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Need help in c++ and windriver
Are you using the SimpleTemplate example? What kind of drive are you planning on? Arcade drive? Tank drive? How many motors, and do you have your control system all wired up? And have you looked at the documentation?
http://www.chiefdelphi.com/forums/sh...ad.php?t=71498
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 13-01-2009, 18:24
AKA: jasmin johnson
yes we used the simple template.... we are planning on using tank drive... we have 4 motors...yes the control system is wired up
Thankyou
Unread 13-01-2009, 18:50
wt200999's Avatar
Texas Instruments
AKA: Will Toth
Read up on the documentation for different objects. You need to create objects for the different things you are using, then you need to define where they are plugged in, then just implement them in the operator control. I would suggest reading up, look in this folder for documentation
C:\windriver\docs\extensions\FRC\
here is an example adapted from the simple robot example:
class RobotDemo : public SimpleRobot
	RobotDrive* myRobot; // robot drive system
	Joystick* m_leftStick;
	Joystick* m_rightStick;
public:
	RobotDemo(void)
		GetWatchdog().SetExpiration(100);
		//candidates are RobotDrive( LeftFront, LeftRear, RightFront, RightRear);
		myRobot = new RobotDrive(1,3,2,4); //adapt to what yours are
		m_leftStick = new Joystick(1); //once again adapt these to what you have
		m_rightStick = new Joystick(2);
	void Autonomous(void)
		while (IsAutonomous())
			GetWatchdog().Feed();
			//auton code here
	void OperatorControl(void)
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			myRobot->TankDrive(m_leftStick, m_rightStick);
help:Downloading the project in windriver mahmosh C/C++ 5 10-01-2009 10:08
WindRiver Installation Issues - can you help a brother out? tdressel C/C++ 1 08-01-2009 00:42
Need interupts help, and another question... Kevin Karan Programming 7 22-02-2004 11:20
We NEED 8-inch wheels and programming help archiver 2001 7 24-06-2002 00:29
