Go to Post The more women we have as 'rock stars' in FIRST, the more girls we'll see celebrating math and science and the doors they can open. - JaneYoung [more]
Unread 13-01-2009, 16:56
KRibordy KRibordy is offline
FRC #1000 (Cybearcats)
KRibordy is an unknown quantity at this point
WindRiver "TankDrive"
I followed the guide as to how to set up a project and it seems much simpler than MPLab. I'd like to be able to set up the TankDrive function so that we can automatically adjust to half speed if the trigger on the joystick is pressed, among other things. I've been looking for where the "TankDrive" function is defined so I can edit it.
Is this what I should go about doing? If not, what should I do?
Unread 13-01-2009, 17:20
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: WindRiver "TankDrive"
You have a couple ways on implementing it. I wouldn't suggest editing the WPILib, at least not yet as there will still be patches that may overwrite what you do. You could create your own class and inherit that. Or you could create your own Joystick class instead, inheriting the Joystick and adding the scaling to the GeyY() function (or if you assign a different axis for drive). There is also RobotDrive::TankDrive(float leftDrive, float rightDrive) that you could use when the trigger is pressed. The function is defined in RobotDrive.h
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 13-01-2009, 17:29
I think that TankDrive(float leftDrive, float rightDrive) is used in the original program.
But would this work?
within the code, making two variables, one leftHalf and another rightHalf. Then continually assigning each to leftJoystick/2 and rightJoystick/2 respectively?
And then having an
else if (triggerPressed==1) {
    myRobot->TankDrive(leftHalf, rightHalf);
after the if that determines whether to use arcade or tank driving?
Unread 13-01-2009, 17:48
wt200999's Avatar
Texas Instruments
AKA: Will Toth
You could even simplify that instead of having the rightHalf variable:
else if (triggerPressed)
    myRobot->TankDrive(leftJoystick->GetY()/2,rightJoystick->GetY()/2);
Edit: May I suggest having a trigger on each side slow down that side's motor instead of one on one side slowing them both down?
Unread 13-01-2009, 18:13
That's what I was planning on doing. Thanks.
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
