Go to Post I still have 3 good ligaments left and 2 events, so I should be fine :rolleyes: - esquared [more]
Unread 24-06-2002, 00:48
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Nifty Brake Switch
Posted by Justin Stiltner at 2/19/2001 12:03 AM EST
Student on team #388, Epsilon, from Grundy High School and NASA, American Electric Power, Town of Grundy.
In Reply to: Nifty Brake Switch
Posted by Ed Sparks on 2/13/2001 6:27 PM EST:
: Want to be able to turn those Victor's brakes on (say when you are on the bridge)? Fasten a magnet to one of the servo's link arms and rotate that magnet past a couple of reed switches that are wired to the Victors where the brake/coast jumper is (use a PWM cable). Pay attention to what your servo does when the power is removed from OI and program wisely!
We did somthing similar last year with a servo and contact switches.
Justin Stiltner
Team #388
Epsilon
Grundy Va,
[IMG] code is Off
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
