Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 24-06-2002, 00:48
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
1 or 2 phase switch
Posted by Sharif Mukhashen at 2/13/2001 7:06 PM EST
Student on team #301, P.R.O.B.O.T.S, from Dearborn High School and Ford.
Can we use a gen. 1 or 2 phase switch on our control board? This switch will go to one of the ports.
[IMG] code is Off
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
most important phase? Jeremy L Rules/Strategy 3 15-01-2003 15:21
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
