Go to Post You can't unwind after build season knowing that competition season is just around the corner! ;) - Hallry [more]
Unread 13-01-2009, 19:23
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Field Corner Dimensions Missing from Field Drawings?
So...I must be missing it...
Anybody know where we can find the corner dimensions of the Regolith? We are trying to trim the corners on our field but I can't find the exact dimensions anywhere... They aren't in the new field markings and dimension files either, unless I'm just missing it...
Thanks...
I would rather find out I'm missing it from here before bugging the GDC on the Q&A...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 13-01-2009, 19:50
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Field Corner Dimensions Missing from Field Drawings?
I'll guess the design intent is to keep the exposed carpet (aptly called the Lunatic Fringe by a prominent CDer) width uniform around the regolith.
The fueling station with is shown as 4' 2-1/2" on the 2009 Arena Layout and Markings drawing. The fringe width (space between regolith and rail) is eighteen inches. Knowing those two dimensions you can construct the triangular cut-out at each regolith corner.
However, my guess above is not consistent with the detailed Launch Pad view shown on the second sheet of the 2009 Arean Layout and Markings drawing. That view seems to show that the regolith corner cut-out is NOT perpendicular to the long axis of the Launch Pad. Is this the source of your confusion?
Richard Wallace
since 2003
Unread 13-01-2009, 19:57
Don Wright's Avatar
FRC #0469
The side carpet fringe is 18" on the sides and 24" on the ends (I'm guessing the difference is for the bumpers on the ends of the field). The cut on the corners from the drawing doesn't look parallel to the diagonal corner field pieces so there are two missing dimensions for the Regolith corner trim specification...
Product Manager
[FTC]: Field Drawings? Madison FIRST Tech Challenge 1 14-09-2008 15:16
2007 Field Drawings and Dimensions sanddrag Rules/Strategy 4 07-01-2007 12:15
Field Dimensions archiver 2000 11 23-06-2002 22:27
Field and shelf missing dimensions kmcclary Off-Season Events 3 12-10-2001 18:21
Field Drawings Update Justin Howard OCCRA 5 29-09-2001 10:28
