Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 13-01-2009, 19:39
Roboham's Avatar
Roboham Roboham is offline
AKA: Jacob Ward
FRC #1569 (Haywire Robotics)
Roboham is an unknown quantity at this point
To those using rollers:
My team is having a bit of trouble. We've decided to use a type of roller system, with the rollers made of PVC pipe. We were able to crudely throw together a working prototype. Now, we need a more precise design. How did your teams snugly mount the pipe to the motor? Any help on this would be greatly appreciated.
Unread 13-01-2009, 19:44
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: To those using rollers:
We haven't tested or built this yet, but the plan I've been working with would be to install a plastic plug onto each end of the pipe, and then screw an andymark hub (or Kop or custom made equivalent, depending on motor) onto its face, which the motor would be attached to.
For smaller pipe, the same concept, except with a doughnut instead of plug would work as well.
Unread 13-01-2009, 20:33
DonRotolo's Avatar
Back to humble
FRC #0832
We are not using rollers of this type this year, but in the past we have cut a plug of 1" thick wood and forced it into the end, and secured it with a small wood screw through the plastic into the wood. The center of the wood can have a hole in it, or a plate or hub mounted to it, to interface with the motor or gearbox shaft. Alternatively plastic can be used, but we found that wood was stronger/easier/tougher/lighter/cheaper.
Unread 13-01-2009, 20:43
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
This idea works really well. Especially if you're using pvc. U can use pvc glue to connect a cap onto the end of the pvc and screw or bolt on a sprocket and drive with a chain, or belt, if u prefer.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 13-01-2009, 20:58
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Well, first of all, why PVC? Its slippery and breakable, why not go for a piece of dowel? The wood rollers on our prototype collector were golden.
As for motor mounting, if you want direct drive, just interface with a hub, as has been said previously. Otherwise, pick a gearbox and run a chain to a sprocket attached via the hub method. The second method offers adaptable positioning and gear reduction, but sacrifices a bit of space.
Best of Luck
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 13-01-2009, 21:18
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Have you thought about a flange? You could bolt a hub or sprocket to a flange.
Brian K
Team 1225 Robotics Mentor
Unread 13-01-2009, 21:58
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
we're using a lathe and a local machine shop to take UHMW 2" dowels and make the ends of it 1/2" with a keyway and setscrew so we can run a hub-sprocket to them.
Unread 13-01-2009, 22:15
DeMentor's Avatar
DeMentor DeMentor is offline
DeMentor
AKA: Mike Hinkle
FRC #1865 (RoboBuffs)
DeMentor has a spectacular aura aboutDeMentor has a spectacular aura aboutDeMentor has a spectacular aura about
Send a message via Yahoo to DeMentor
Talking Re: To those using rollers:
We'll use rollers too. I like the wood dowel ideas -- agree they've got better surface friction and are less breakable, but we want to do some special surface and handling tricks that will be better with PVC pipe. To attach a drive, drill a hole in the center of an end cap, and place a screw of the right diameter (1/4" or 3/8", depending on the specific purpose of the roller) through the hole, then secure it with a washer, lock washer and nut -- and also some epoxy on the screw head (inside the end cap). Then glue the end cap on the roller/pipe. Can then place either a hub, sprocket or motor drive attachment/coupling directly on the screw. We plan to build several roller assemblies, and drive them all from a common shaft going through the base of the robot -- with drive sprockets attached where necessary.
Good luck!
Unread 13-01-2009, 22:27
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Here what we are doing-
Instead of PVC we used ABS (it is lighter). The Tube is 1.5in diameter. We put some caps at the end and did our best to find center. We have no lath but it look pretty good of the low RPM application. The hole was just the right size for some flange bearings to be pounded in. After that we we used the 1/2in aluminum rod that was in the KOP. Since the ABS is only supported at the ends we cut a fiberglass disc to fit in the inside diameter of the ABS. This provides enough support to keep the ABS for bowing in the direction of tension. Callers work great to keep the disc in place.
Stop! Don’t make the mistake we did, use polycord (here is a good thread. To keep the polycord in place use a pipe size that will fit around the outside diameter of your pipe. Cut thin section of the pipe (1/2in) and glue them in with enough spacing for a polycord to fit between the two, now your set.
Here is a pic of your progress. We are not entirely done yet.
Hope it was helpful!
Good Luck!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 13-01-2009, 22:33
Ferdi17 Ferdi17 is offline
AKA: Steve
FRC #1073 (The Force Team)
Ferdi17 is an unknown quantity at this point
depending on if it would get in the way it is always possible to use a pin or set screw to hold an axel, sprocket, or other pipe to the pvc
Unread 13-01-2009, 22:35
Polycarb tubing with a plug of HDPE or UHMW about 1/2" - 1" thick. Then we mounted the sprocket or hub for belting.
Unread 14-01-2009, 02:37
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
For attaching the PVC rollers on our prototype I lathed down a piece of Delrin round stock to .003 in larger in the diameter then the ID of the PVC (on my PVC this was 2.035 in) Then I drilled and tapped 1/4-20 center holes into the Delrin and pressed it into each side of the PVC. This gave me perfect point for axels. Also as tube guide Im going to pop rivet strips of treading. Its a bit expensive but for my application I really need the extra grip. You can see 254 use the method on the bottom roller of their 2006 design.
http://team254.bcp.org/images/2006r.jpg
Good luck!
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
rollers for 173 (Rage) in 2002 jblay General Forum 6 09-01-2009 22:26
pic: Team 987 The High Rollers' 2008 Robot 987HighRoller Extra Discussion 7 10-03-2008 23:13
High Rollers video natis Rumor Mill 0 17-02-2006 20:20
pic: 885 rollers lower front CD47-Bot Robot Showcase 5 26-02-2004 22:33
Ball Rollers archiver 2001 8 23-06-2002 23:26
