Go to Post FIRST is all about working with others. - briholton [more]
Unread 13-01-2009, 19:44
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: To those using rollers:
We haven't tested or built this yet, but the plan I've been working with would be to install a plastic plug onto each end of the pipe, and then screw an andymark hub (or Kop or custom made equivalent, depending on motor) onto its face, which the motor would be attached to.
For smaller pipe, the same concept, except with a doughnut instead of plug would work as well.
rollers for 173 (Rage) in 2002 jblay General Forum 6 09-01-2009 22:26
pic: Team 987 The High Rollers' 2008 Robot 987HighRoller Extra Discussion 7 10-03-2008 23:13
High Rollers video natis Rumor Mill 0 17-02-2006 20:20
pic: 885 rollers lower front CD47-Bot Robot Showcase 5 26-02-2004 22:33
Ball Rollers archiver 2001 8 23-06-2002 23:26
