Go to Post I'm going to go out on a limb and say that we have to displace objects and/or robots in order to score points. - pfreivald [more]
Unread 12-01-2009, 19:12
Lord Byron's Avatar
Lord Byron Lord Byron is offline
AKA: Tim Sebek
FRC #0538 (Dragon Slayers)
Lord Byron is an unknown quantity at this point
Fubar Gaming Adapter
Our gaming adapter has had a whole host of problems.
We can finally access the interface to change the ip, but the bridge kicks us off after a few minutes without letting us change the ip. We have a suspicion that the bridge we received might be a substandard product. If this is the case, is it possible to send a fubar part back to FIRST and get another?
Also, does the frequency we are set on have anything to do with our problems?
You have a ramen doctor in your secret ramen base!?!
Unread 13-01-2009, 11:55
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
Re: Fubar Gaming Adapter
Are you trying to change the IP through the wireless or while you're tethered to your bridge with an ethernet cable? You shouldn't be getting kicked off if you're hard connected.
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 13-01-2009, 12:54
It's possible to get kicked off the Bridge if the power feeding it is iffy.
For instance, whenever the barrel connector is loose or makes a poor contact.
Unread 13-01-2009, 20:07
Lord Byron's Avatar
AKA: Tim Sebek
We've tried both hardwired and wireless, and different power cords and outlets. It still refuses to work. We have tried different browsers, computers, Ethernet cords, default IP after reseting, installation software, different router settings, and no security.
All in all, everything we've tried points towards the bridge being broken.
I also recently learned that when we first connected the bridge to a power source, there was a spark at the connection. This has helped to convince me that the bridge really is damaged.
Unread 15-01-2009, 17:43
Lord Byron's Avatar
AKA: Tim Sebek
UPDATE: We have narrowed the problem down to the wireless part of the gaming adapter. It now functions normally when wired, but is unable to receive wireless input.
Some Online Gaming Josh Goodman Games/Trivia 34 22-04-2010 21:34
Gaming Adapter Orientation On Robot: Does it matter? Tom Line FRC Control System 1 12-01-2009 12:48
Help with the gaming bridge!! A-Prime Electrical 11 31-12-2008 15:50
Gaming to help vision! Heretic121 Chit-Chat 3 07-02-2007 19:02
