Go to Post Chief Delphi down for a few hours ON A WEEKEND??? This is MADNESS! - [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 12-01-2009, 20:24
CDlabrador's Avatar
CDlabrador CDlabrador is offline
AKA: Jonathan
FRC #1388
CDlabrador is an unknown quantity at this point
Question Making the Labview program stick
Our programming team is having trouble getting the .vi files to "stick" to the cRIO. We download it to the cRIO and it only stays on as long as the cRIO is on. We wish to make it so that a select program will remain on the cRIO until we change the program otherwise. Any help is appreciated!
Unread 12-01-2009, 21:37
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Making the Labview program stick
http://www.usfirst.org/community/frc....aspx?id=10934
You need to check out all of the LabVIEW resource links that are accessible via the above website. These are the definitive docs from NI to answer your questions. Specifically, you need to learn the difference between running from RAM and building/deploying/run as startup.
Russ
Unread 13-01-2009, 12:49
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
You should definitely read the documentation for this !
Short answer, From project explorer , right click on cRio to "Build" and then right click to "run as startup"
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 13-01-2009, 20:19
CDlabrador's Avatar
AKA: Jonathan
FRC #1388
Thanks a ton guys! I'll try it out, and I'll be sure to read the manuals a bit more thouroughly
How do you program joystick buttons in LabVIEW? darkpheonix NI LabVIEW 10 13-04-2014 10:20
Help to Deploy a Program in Labview. Delian NI LabVIEW 7 10-12-2008 21:13
HELP!!!!!! LABVIEW IS MAKING ME MAD!!!! cdennisxlx2 LabView and Data Acquisition 2 21-03-2006 21:50
Making a LabVIEW Multimeter Bruce Barber National Instruments LabVIEW and Data Acquisition 4 10-02-2006 11:54
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
