Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 13-01-2009, 20:43
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
Re: To those using rollers:
Originally Posted by rocketperson44 View Post
We haven't tested or built this yet, but the plan I've been working with would be to install a plastic plug onto each end of the pipe, and then screw an andymark hub (or Kop or custom made equivalent, depending on motor) onto its face, which the motor would be attached to.
For smaller pipe, the same concept, except with a doughnut instead of plug would work as well.
This idea works really well. Especially if you're using pvc. U can use pvc glue to connect a cap onto the end of the pvc and screw or bolt on a sprocket and drive with a chain, or belt, if u prefer.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
rollers for 173 (Rage) in 2002 jblay General Forum 6 09-01-2009 22:26
pic: Team 987 The High Rollers' 2008 Robot 987HighRoller Extra Discussion 7 10-03-2008 23:13
High Rollers video natis Rumor Mill 0 17-02-2006 20:20
pic: 885 rollers lower front CD47-Bot Robot Showcase 5 26-02-2004 22:33
Ball Rollers archiver 2001 8 23-06-2002 23:26
