Go to Post before you post, ask yourself: Is there a good reason to post this? - Jeff Waegelin [more]
Unread 13-01-2009, 13:53
marisaDKNY marisaDKNY is offline
The crazy person
AKA: tomato
FRC #0647 (CyberWolves)
Team Role: Electrical
marisaDKNY is an unknown quantity at this point
Send a message via AIM to marisaDKNY Send a message via Yahoo to marisaDKNY
Cero and Electrical Help!
My team started late on putting together the electronics. But we got everything ready for the benchtest, the jaguars LED lights kept on flashing orange. Untill some how it finally work. Out configuration was check out by our mentor and said everything is wired right. So, then we update the system and the jagaurs won't work. We think it may be the cero. What is your idea's?
Unread 13-01-2009, 20:50
Re: Cero and Electrical Help!
Tell us what you updated, and how you did it. Describe what the Driver Station displays on its screen. Without more information, it's hard to give good guesses as to what might be the problem.
My guesses: maybe you didn't update both the cRIO and the Driver Station, or maybe you didn't set your team number properly on both of them.
Unread 13-01-2009, 21:41
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Did you download any program into the cRIO?
If you don't have any code downloaded, what do you expect it to do?
Try downloading a simple program like the Robot Main when you start a new project.
Only do this if you have updated both the cRIO and the ds.
electrical & pneumatics help samir13k Electrical 4 01-12-2008 18:38
non frc question: electrical series to a parallel??? HELP Tri_Lam Math and Science 0 02-03-2007 16:56
Electrical Systems and ideas... mechanicalbrain Electrical 28 17-08-2005 07:03
Need help ordering electrical components Charly Electrical 4 24-01-2005 12:38
Electrical connections and multimotor mechanisms kmcclary Off-Season Events 2 11-10-2001 14:15
