Re: Axis Camera Movement
Move as in with servos? in Labview?
Are you using the locate colored object example or the servo camera example or none of those? The servo camera example needs a watchdog, so if you add that, it should work for tracking. I need more information to properly answer your question ![]() |
| AXIS Camera | nickmagus | Programming | 1 | 03-01-2009 20:06 |
| very weird camera movement! | graphite | Programming | 3 | 14-05-2006 05:23 |
| Camera Movement has Ceased | phrontist | Programming | 2 | 11-02-2005 10:22 |
| NEED HELP WITH CAMERA MOVEMENT | nm4 | Programming | 3 | 10-02-2005 17:17 |
| camera tracks but no movement from Robot | Stillen | Programming | 4 | 04-02-2005 17:16 |
