Go to Post Of course 254 owns Battlebots too - dodar [more]
Unread 13-01-2009, 22:05
Bharat Nain's Avatar
Two Color Tracking Demo
Here is a version that tracks the gimbal type setup provided by FIRST. It works in autonomous mode. WPI has finally released it.
http://first.wpi.edu/FRC/frcupdates.html
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 13-01-2009, 22:10
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Re: Two Color Tracking Demo
Anyone find the labview version yet?
EDIT: usfirst has(will have) a link to it on their 2009 control system page. I guess I'll just wait for that to be up.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 13-01-2009, 23:50
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Thanks for the post and letting us know.
R.C.
MadTown Robotics Team 1323
Unread 14-01-2009, 09:18
Greg McKaskle Greg McKaskle is online now
The LV version is at http://joule.ni.com/nidu/cds/view/p/lang/en/id/1215
Greg McKaskle
Unread 14-01-2009, 09:45
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
I can't compile this code. The module Target.cpp calls a function "InArea" that is defined in the WPILib module TrackAPI.cpp. TrackAPI.h, however, does not declare this function. I could easily add this declaration to Target.cpp but I wonder if this was written for a WPILib that hasn't been released yet. Some other posts have indicated that there are bugs in the vision system and this example may not address them. Has there been any WPILib update since 1/1/09 that I don't have?
Unread 14-01-2009, 10:01
foemill's Avatar
foemill foemill is offline
What do you mean it's overweight?
AKA: Eric Miller
FRC #1270 (Red Dragons)
foemill is on a distinguished road
the function "InArea" can be found in the source code for build 1562 found here. The source has changed since the kickoff because the code I have from just before the kickoff doesn't contain the InArea function either.
Try re-installing the Workbench update. It looks like they may have added it to this install. Otherwise you'll have to re-build the source and link in the WPIlib.a file generated in the make process. The default location for the WPILib source tree ended up in C:\WinDriver\vxworks-6.3\WPILib.
Unread 14-01-2009, 11:40
FRC #0138
I just downloaed the build 1562 from the WPI site and it is identical to the one that I downloaded on jan 2. My issue isn't that the function InArea is missing from the library but that the declaration of it is missing from the header TrackAPI.h. The latest version does not fix this. If I put the declaration for InArea in target.cpp than the demo compiles and links.
I suspect that they have added the declaration of InArea to their version of the library but have not yet released it. The demo, however, seems to have been built with a newer library than the one we have.
Unread 14-01-2009, 12:17
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
fabalafae is an unknown quantity at this point
Thanks for the LV link.
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
Unread 14-01-2009, 15:27
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FYI.
It's possible to build the Camera Gimbal slightly back the front.
Looking at the gimbal from the front of the robot, the servo needs to be on the left hand side. It will go together just fine with the servo on the right, but the net effect is that up and down will be reversed on the Y servo.
It's easy to spot this (as in my case) because when the camera sees the target, it sweeps up or down away from it.
I tried fixing it in software but I couldn't quite get it working, so I opted for fixing the camera.... It just meant detaching the servo horn from the tilt servo, and flipping the camera plate by 180 degrees. (Of course you have to invert the camera and rotate the base by 180 on the robot as well).
It's a great example VI (for LabVIEW), able to be almost dropped right into either of the robot templates.
Phil Malone
http://www.GEARSinc.org
Unread 14-01-2009, 17:22
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Is there anything special that needs to be done to use the LabVIEW version of this code? We tried running the code on the cRIO using the run button, and it refused to communicate. It was communicating just fine with other code we'd been working with (using the Basic Robot Main VI), so I'm inclined to think that it's some sort of missing software update, but I'm not sure what that could be. Our team has update 2.0 of the FIRST robotics update (found using the about menu item).
We have gotten the camera to work before, connected to the cRIO and directly to our programming laptop.
Please help!
Unread 14-01-2009, 19:39
PhilBot's Avatar
AKA: Phil Malone
Hi
Yes..... Most "sample" programs come configured with a generic tean number (read IP address) or none at all.
Once you open the project, you will see the IP address as part of the realtime program node name (cRIO Controller 10.0.0.2).
Right Click on the Realtime node and select Properties.
From there you will see a place to change the program's name and IP address.
Set it based on your team # 10.xx.yy.2
Now you sould be able to connect using the run button.
Make sure you RUN the main vi (eg: Two Color Servo Camera Example.vi)
Have Fun.
Phil Malone
Unread 16-01-2009, 14:06
Yes, that was the problem. Thank you, PhilBot.
Unread 17-01-2009, 12:51
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
oh someone stated that the code must be run in autonomous mode...
is this true? that might be why iv had such a hard time all along.
Unread 17-01-2009, 13:28
Dr Nick Dr Nick is offline
FRC #0501 (The Powerknights!)
Dr Nick has a spectacular aura aboutDr Nick has a spectacular aura about
Send a message via AIM to Dr Nick
@dani - The tracking is only active in autonomous mode, the tele-op is just the standard SimpleRobot tele-op.
Does anyone know if there are step by step instructions for asembling the camera gimbal assembly? I found the drawing on the FIRST site but the only part I can't figure out is how to attach the "Axis Case" part to the camera? Other than that I could probably figure the rest out by looking at the drawings.
Unread 17-01-2009, 13:30
AKA: Dani
sorry which part... it is relatively easy just clarify which part and i can help you out
Camera tracking between two lights Ankush Dhar Programming 2 12-02-2007 23:44
Tracking two lights Render Programming 5 29-01-2007 18:14
Camera tracking demo in easyC or WPILib BradAMiller Programming 0 25-01-2007 14:01
Tracking Color? haywirerobotics Programming 0 14-01-2006 13:55
tracking two tetras? Anton Programming 5 09-02-2005 15:02
