Go to Post "What's this on the floor? 'Team 71 2005 strategy and design notebook'?" DRAT! I better call Bill and get this in the mail. - Gary Dillard [more]
Unread 13-01-2009, 09:18
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Using the analog sensor .vi's
So after 6 hours of troubleshooting, my programming team and I have finally found out why the analog sensors vi's weren't working in labview. First of all, when the "open" vi asks for a channel and slot input, instead of just putting in 1, 2, etc... we needed to put in "slot one" and "AI 1" for slot one channel one. Secondly, since we didn't have any analog output devices we decided we would just use channel 8 in slot one, which should have given us a modified battery voltage response. The only problem is that it seems that there is a conflict with this situation. I believe that since the DS is also trying to read the battery voltage from this channel, and so there is some sort of a programming conflict and the battery voltage won't show up in labview. I don't know if there is any work around to this problem, I just thought I would let other teams know in case there were in the same situation as ours.
Relax! It's only ones and zeros!
Unread 13-01-2009, 09:32
Re: Using the analog sensor .vi's
The first part of that, using 1 instead of the enum "AI 1" will result in a coercion dot, and will work as long as you know the encoding. This is sometimes useful when casting between enums or when using a loop to get all values. So in other words, this isn't really an error, but when doing constants, it is much more readable to use the specific ones.
Greg McKaskle
Unread 13-01-2009, 17:38
Hazmatt's Avatar
AKA: Matt
Greg McKaskle
Hm, i'm really interested to know where I could have read about this beforehand.
Unread 13-01-2009, 20:47
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
When make controls and constants for in LabVIEW (especially for WPILib) it will help you greatly if you right-click on the input terminal and select Create » Constant/Control. This will ensure the constants and controls are the correct data type(s) etc.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 13-01-2009, 22:49
Anytime you are given a subVI that you intend to use, I recommend looking at the front panel. You will usually get a better sense of what the author intended to have wired in. You can then copy/paste, or from the icon create control or constant. The create... is a short cut to opening and copy/paste.
Greg McKaskle
Unread 13-01-2009, 22:57
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
I call that action the "easy button" with my team.
I can't beleive there isn't a hotkey for "create constant"
Phil Malone
http://www.GEARSinc.org
Using Analog Inputs as Digital (on the OI) Guy Davidson Control System 16 10-03-2008 17:17
pic: Robostang's Analog Sensor test software Robostang 548 Extra Discussion 11 23-12-2007 09:55
Using gyro.c with other analog sensors no go Astronouth7303 Programming 17 03-01-2006 21:04
Using gyro with other analog sensors...again demerski Programming 0 19-02-2005 08:23
Using and Coding an ultrasonic sensor Jaine Perotti General Forum 14 06-08-2004 14:13
