Problem Setting Up Router
We tried setting up the router earlier today. We went to 192.168.1.1 and entered the username and password found in the 2009 FRC Control Manual, but it didn't accept the password.
Here's what we did so far, in order: - tethered benchtop test - firmware update on Driver Station - configuration of wireless bridge We installed the software that came with the router on the laptop we're using. I don't think this should cause any problems, but I don't know for certain. What do you think is going on? |
Re: Problem Setting Up Router
You shouldn't use the code that came with the router.
You can reset the router to get back to the default state, then follow the Control System Manual chapter 5 instructions. |
It works now. Thanks for your help!
| Use of Wireless Router | Andrew Lindsay | Rules/Strategy | 3 | 12-01-2009 14:17 |
| CNC Router/Mill | Andy L | Technical Discussion | 80 | 03-11-2008 02:14 |
| Wireless Router Issues | zim2411 | Scouting | 17 | 09-04-2008 22:24 |
| Bypassing router | Mark Rozitis | IT / Communications | 17 | 13-12-2007 18:06 |
| Linksys Router Help | mtaman02 | Chit-Chat | 10 | 18-03-2004 01:04 |
