Go to Post Yup. Two world champs on one alliance, out in the quarterfinals. Only at IRI. - Norman J [more]
Unread 13-01-2009, 23:05
Questions4mQ202 Questions4mQ202 is offline
FRC #2348
Questions4mQ202 is an unknown quantity at this point
Accelerometer Help!
Does the accelerometer have to be connected to specific pins on the analog breakout (i.e. AI1 - AI8)? Is there a specific test we could perform to check whether it's operating correctly? We tried using the oscillator but the data we were getting weren't exactly helpful.
Unread 13-01-2009, 23:10
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Accelerometer Help!
There's no specific port for it, just don't use AI8 on module 1, since that's for battery voltage.
The easiest test is to turn it vertical and note the change in reading. If you lay the board flat, you should get the steady state center reading. By standing it up, you are putting one of the two axes in line with acceleration due to gravity. Measuring in this position should give a reading of the steady state plus or minus (depending on the orientation) the V/g sensitivity of the accelerometer.
Unread 13-01-2009, 23:54
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
How would you be able to read what values the accelerometers and sensors are outputting?
Unread 14-01-2009, 04:19
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
To read the values of the accelerometer, just run accelerometer example code on the LabVIEW library. With the example code you should be able to read the inputs of the accelerometer.(just make sure you use the right port for it )
you can find this example under(if you have labview)
c:\Program Files\National Instruments\LabVIEW 8.5\Examples\FRC\Accelerometer
Unread 15-01-2009, 19:44
FRC #2348
Yayness! Thanks for your help
Accelerometer help Red Mage Programming 3 30-01-2008 18:49
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
Accelerometer Connection Help crazykid234 Electrical 2 11-02-2005 08:23
URGENT! We need help with the accelerometer lkdjm Technical Discussion 0 08-02-2005 14:35
