Go to Post We make ourselves better by lifting others and standing on their shoulders, not by knocking them down. - Taylor [more]
  #91   Spotlight this post!
Unread 12-01-2009, 08:35
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: 4WD Turning Difficulties
Originally Posted by ZakuAce View Post
Has anyone seriously considered a robot with two wheels in the middle as the drive wheels and having it pivot? We're thinking it would get good traction, as all the weight (well most of it) would be on the two drive wheels, and the trailer would help balance out the wheels to keep the center of gravity in the middle. Also, the simplicity factor would allow us to spend more time making a way to score.
We considred it for awhile but figured we could not use the hitch to keep us balanced and it was too risky. But we are trying to keep the CG over the rear wheels as much as possible and trying to achieve about the same thing.
Doug Leppard
  #92   Spotlight this post!
Unread 12-01-2009, 11:10
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
we were thinking of using more wheels to support our robot at the front and back when it pivots. The mentors were thinking that even though the robot may be resting on an un-powered wheel at some point, the amount of force that is placed on those wheels will be negligible, as most of the force will still be on the center drive wheels. I guess it is more like the 6 wheel drive with the lowered center drive wheels, only we'll use 5 (2 drive, 2 in front on each side of our ball gatherer, and 1 in the back)
EDIT: So... the trailer hitch can never change from that height? Well that could be a problem. I suppose we could have the rear supporting wheel powered and at the same height as the main drive wheels, and have it programmed to run only when moving foreword and backword. I really want to keep the number of drive motors as low as possible.
I'll bring up this idea that was really good, but ultimately shot down because of complexity.
One of the mentors brought up an idea of a three wheeled system. it would work similar to a crab drive, but has a huge difference. The base that the wheels are attached to would be able to rotate, or rather, the robot would rotate around it. The wheels move, then the entire body moves around the base to face the direction of movement. It seemed really stable and a great way to keep the same weight distribution on all wheels, but it was rather complicated and could interfere with a ball gathering mechanism.
  #93   Spotlight this post!
Unread 12-01-2009, 11:59
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
To this general topic about 4WD: I designed the wheel base to be wider than it is long, the closest being... make sure the insides of the wheels make a square. This way the wheels don't have to slip along an arc across a surface while it's turning.
http://www.linkedin.com/in/erapacki
BUZZ 175 (01, 02) - NUTRONS 125 (03, 04) - QUEEN 1975 (06)
Beantown Blitz Founder (04) - FIRST Robotics Conferences (04) - Boston Regional Volunteer Coordinator (06)
  #94   Spotlight this post!
Unread 12-01-2009, 13:11
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
From the drawings of the swivel and other parts it appears that the design intent is to create a rigid attachment without freedom to rotate about the trailer wheels.
The hitch pin is a close fit. The close fit requires that the hole in the swivel have a vertical axis. The same is true for the holes in the c-channel. The 0.385 of gap is, IMHO, intended to allow for the tolerances in the height of the hitch swivel (when level) and the robot c channel (when level). I would not expect the swivel to ride much up and down on the pin. Of course I could be wrong and only testing will reveal how rigid the attachment is in practice.
  #95   Spotlight this post!
Unread 12-01-2009, 21:05
ZakuAce's Avatar
AKA: Garrett
I was thinking the same thing.
Also, I talked with the mentors today, and one of them brought up a really good point. If this was illegal, in theory, then suspension could be called illegal, since it changes the height of the robot, and could potentially make the hitch higher or lower than 2-13/16 inches from the ground. So I think we're sticking with our current plan. We're only going to have the height of the drive wheels and the wheels it will pivot onto on the front and back a 1/16 of an inch or less difference.
  #96   Spotlight this post!
Unread 12-01-2009, 23:35
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
You are correct. This will work, however, the math proves you are not getting the full force of straight in line wheels and mechanums have a tendency to be difficult to steer straight plus a tendency for the operator to over correct. That's why so many teams experiment with a gyro feedback to help drive straight and side to side. The low friction of the surface means that the gyro would try to stop a skid but only manage to spin the wheels really fast... the exact opposite of what you need. Slower speeds seem to give more control but they're... slower. speed will be a factor in this game almost as much as friction.
Just my 2 cents
Steve
Originally Posted by Teamcap.2395 View Post
Okay, so here is a crazy thought I had...
If you did a 4WD in the same configuration as a omni-wheel drive...
...(like this) (In the same fashion as "The Pre" )
|= Chassis Perimeter
// = Wheels
. = space filler
___________
Would the low amount of friction on the wheels allow
the robot to move like an omni-drive?
I don't know how slick the flooring is because I was not able to attend a Kick-off.
But from what I have heard, it sounds pretty slippery.
Any guesses on how well this would work?
Edit: Hachiban beat me to it!
  #97   Spotlight this post!
Unread 13-01-2009, 23:29
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Purely anecdotal, but tonight we put our bot on regolith, and managed to steer without too much difficulty. It is a 4WD in standard ("portrait") orientation, with the difference being we incorporate a shorter wheelbase (to increase the space for the gullet). To use the now-standard way of drawing:
|_______________|
________________
While I can't say I've read every word of this thread (and especially not all the links off of it), I have to wonder what we did "wrong" to get it to steer. Could it be the shortened wheelbase?
(Yes, pictures coming)
"It's NOT Just A Robot Thing!"
  #98   Spotlight this post!
Unread 13-01-2009, 23:36
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The shortened wheelbase will make a big difference.
We got our new wood chassis rolling tonight
http://www.youtube.com/watch?v=Yb8IPQYp_M0
The concrete floor is pretty smooth, and it probably has a bit more friction than the proper material (which we need to buy soon!). Handling is pretty good...all things considered...but having it light, no trailer, wrong floor, everything will be different in the game.
  #99   Spotlight this post!
Unread 13-01-2009, 23:37
President, VEX Robotics, Inc.
Mr. I,
Did you have the trailer attached during your driving? We noticed a considerable difference with and without the trailer. Driving without the trailer was quite fun, but driving with the trailer was just painful.
Paul
  #100   Spotlight this post!
Unread 14-01-2009, 07:57
Mr_I's Avatar
Originally Posted by Paul Copioli View Post
Mr. I,
Paul
Good point. Tonight, maybe?
  #101   Spotlight this post!
Unread 14-01-2009, 13:22
mototom's Avatar
mototom mototom is offline
AKA: Tom Boehm
FRC #0329 (Raiders)
mototom is an unknown quantity at this point
Originally Posted by dlavery View Post
As one benchmark, after a bit of practice I was able to take a standard kit-bot system with trailer attached and run it from one end of the Crater (starting with the Trailer touching the Alliance Station Wall) to the far end, execute a 180-degree turn and make contact with the far wall, and run back to the starting wall in about 12 seconds. This was repeatable several times.
-dave
Wow Dave! That is some accelleration! Were you taking advantage of the carpet? What drive configuration were you using? Got a video?
  #102   Spotlight this post!
Unread 14-01-2009, 14:49
Brandon Holley's Avatar
If you have not hooked up a trailer to your robot, do it.
It may seem optimistic when you are driving just the robot, but as Paul said, it is just PAINFUL to drive with the trailer on.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #103   Spotlight this post!
Unread 14-01-2009, 18:05
RobotDevil1985's Avatar
RobotDevil1985 RobotDevil1985 is offline
FRC #0533 (PsiCotics)
RobotDevil1985 is an unknown quantity at this point
|= Chassis Perimeter
// = Wheels
. = space filler
___________
We tested that theory, granted we were on a smooth tile instead of the flooring, and found that without the ability to guarantee that all the wheels are on the floor with the same pressure. Otherwise the robot will veer uncontrolably depending on which wheels are in contact.
  #104   Spotlight this post!
Unread 15-01-2009, 13:26
jreuter jreuter is offline
FRC #1073 (Force Team)
jreuter has a spectacular aura aboutjreuter has a spectacular aura about
"I have to wonder what we did "wrong" to get it to steer. Could it be the shortened wheelbase?"
The spreadsheet model (http://www.chiefdelphi.com/media/papers/1917) predicts that you should NOT be able to turn a "portrait" tank drive robot, if you use the published coefficients of friction. However, I've seen several posts which claim that the .14 lateral coefficient of friction is overstated. If you put lateral coefficients more like the in-line coefficients, the model computes that you will indeed be able to turn.
  #105   Spotlight this post!
Unread 15-01-2009, 14:14
The fact that other people have not produced the lateral coefficient of friction in their tests, and indeed have produced a smaller number...combined with the fact that your robot DOES turn would lead me to believe .14 is wrong.
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
