Go to Post Winning, the objective, the thing you can point to and say "See that? We want to do that. What can we do to make our program better, to improve our chances at that?" is what has grown FIRST from 28 teams in a high school gym to where it is today. - Joe G. [more]
Unread 14-01-2009, 10:12
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Pneumatic Fittings
Last night we came to the realization that no piston fittings came in the KOP like they usually did...so off I went in search for some.
After a couple of hours of CD searching and distributor locating that resulted in dead ends, I finally just Google-searched the part number. Whatdya know, the first link gave me what I needed (woot for Google ). So for any of the teams who are new to pneumatics, here's a bit to save you some frustration. Perhaps this could form into a sticky if enough info gets posted.
Here's a thread that tells where to get cheap fittings -- though you need to email them if you want to get them within a few days rather than a couple of weeks (7-10 days processing + shipping time).
There's a thread around here that lists all of the part #'s for the fittings that typically come in the KOP. For the life of me I can't find it...so for now here's a link to purchase the pneumatic elbows that fit into the smaller pistons:
p/n KQ2L07-34s
Thanks in advance for any extra info that gets posted!
GitHub
Unread 14-01-2009, 10:53
falconmaster's Avatar
Happy Birthday! falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Re: Pneumatic Fittings
Thanks for posting this! No one answered me before when I posted this topic asking for help!!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 14-01-2009, 11:44
Other commonly needed pneumatic parts.
Tee fitting:
White: http://www.alliedelec.com/Search/Pro...7-00&R=4990150
Basic Black: http://www.alliedelec.com/Search/Pro...7-00&R=4990926
Straight connector:
http://www.alliedelec.com/Search/Pro...7-00&R=4990123
Flow control valves:
http://www.alliedelec.com/Images/Pro...s/499-1574.pdf
A few variations available here, e.g., you might want to meter the flow into an actuator vs. out of an actuator.
Last year's was a: NAS2201F-N01-07S
(This translates to: 1/4" elbow, meter-out, one-touch fitting, NPT, 1/8"port, 1/4" tubing, with seal)
Straight screw fitting:
http://www.alliedelec.com/Search/Pro...-35S&R=4990012
The screw fittings required differ based on the hole in your cylinder, for example, the Clippard storage tank has a 1/4" NPT port, while a typical actuator might use 1/8", and the Bimba rotary actuator requires a tiny connector.
It looks like your source only stocks the 24V coils (we need 12v) on the SMC solenoids, but you can order them from the catalog: http://www.alliedelec.com/Catalog/pf.aspx?FN=1516.pdf
Last year's double solenoid was a: SY3240-6H-S
(This translates to SY3000 series, 2-position single action, base mounting, 12VDC, L-type plug connector, surge suppressor)
The single-action solenoid was a: SY3140-6H-S
Each SMC solenoid also rquires a base: SY3000-27-1T
Parker Plug Valve:
http://www.parker.com/portal/site/PARKER/menuitem.bb22d5a82bbb5b147cf26710237ad1ca/?vgnextoid=a2d9b5bbec622110VgnVCM10000032a71dacRCR D&vgnextfmt=EN&vgnextcatid=10735&vgnextcat=PV609%2 0%20PLUG%20VALVE%20-%20FEMALE%20PIPE%20ENDS&vgnextdiv=687547&vgnextpar tno=PV609-4
Use "locate a distributor"
Nason Pressure Switch:
Call (800) 229-4955 to order part#SM-2B-115R/443
Clippard air storage tanks:
http://www.clippard.com/store/displa...?sku=AVT-32-16
1/4" Tubing:
e.g., http://www.alliedelec.com/Search/Pro...px?SKU=4991634
In general,
Look for 1/4" tubing fittings.
Solenoids need to have 12v activating coils.
We keep some pneumatic info on our team website at: http://www.team358.org/files/pneumatic/
Also the Fluid Power Education Foundation - Pneumatic System education
Here are the Kit suppliers:
Bimba Manufacturing - Special order pneumatic cylinders
Clippard Instrument Laboratory, Inc - air storage tank
Freelin Wade - Pneumatic tubing (50% off, 888-373-9233)
HPE Automation - Teflon Tape
Lord Corporation - Vibration isolaters
Monnier Corp. - Regulator & bracket
Nason Company - Pressure switch
Norgren Regulator - gauge, relief valve
SMC Pneumatics, Inc. - Pneumatic fittings
Festo - Single-action solenoid
Thomas Industries - Air compressor
Wika Instruments - Pressure gauges
Parker - brass fittings
Unread 15-01-2009, 20:33
pneuflex pneuflex is offline
pneuflex is an unknown quantity at this point
Hi everyone,here you could find pneumatic fitttings(one touch fittings) with competitive prices. www.pneuflex-fittings.com We are designing new styles to suit all kinds of requirment.
pneumatic fittings size GeorgeC Pneumatics 7 08-04-2007 15:25
Pneumatic Cylinder yanksrock777 Technical Discussion 2 20-02-2007 11:01
Trouble with the treads in the brass fittings? CalTeach General Forum 2 31-01-2007 07:57
Where to buy T fittings? jgannon Pneumatics 4 22-01-2007 17:24
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
