Go to Post You are beautiful. - Joe Johnson [more]
Unread 14-01-2009, 09:14
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
measuring from bolt to bolt
does the robot get measured from the edge of the frame to the edge of the frame or does it get measured from the top of the head of the bolt to the other side where the head of the bolt is at. What I am getting at is the robot is 29 inches wide when you measure from one bolt to the other side and the head of the bolt. Should we fix it?
Unread 14-01-2009, 09:19
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: measuring from bolt to bolt
yes. The robot must fit in an exact 28X38X60 box. Good Luck
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 14-01-2009, 09:20
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
At the regionals the inspector has the team shove their robot into a box frame that's 28 x 38 x 60 inside. I'm guessing that your 29" side needs to fit into the 28" side. If the bolts stick out they need to be cut down, as the entire robot must fit inside this box frame. The kind inspectors do allow you to turn and twist and basically jam the robot in there (which saved our team at Silicon Valley AND Davis last year), but it's probably better just build slightly smaller than you think will fit.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 14-01-2009, 09:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The robot has to fit inside a box that is only 28" x 38" x 60" inside. Yes, you need to fix it.
We design our robots to be only 26" x 36" but they usually grow as we add parts.
Also we had problems last year with the top of the robot being as wide as the bottom, and the robot would not pass inspection, because the "sizing box" was not square. The base of the box, that the robot sits on, was not perpendicular to the upright parts that are used to check the size at the top. So, I suggest making the top of the robot even smaller, perhaps 24" x 34", if possible. It seems to be better to be conservative, than to have to try to explain to the volunteer inspectors that the test equipment is faulty!
Unread 14-01-2009, 09:24
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Good Point. Our CAD drive base is always 27X37, so we have room to spare
Unread 14-01-2009, 10:26
GaryVoshol's Avatar
Cogito ergo arbitro
Sure it wasn't the robot that was out of kilter? I've seen plenty like that before. But you could be right. Those sizing boxes probably take some abuse getting them to and from events, and could have been warped out of shape. I am surprised that no one would accept that the box was off, if you could demonstrate it to them conclusively. (Corner diagonal measurements)
(since 2004)
Unread 14-01-2009, 10:30
MrForbes's Avatar
AKA: Jim
The problem was that when we put the robot in the box one way, one side of the top of the robot leaned out past the side of the box. When we turned it 180 degrees, the OTHER side of the top of the robot leaned out past the same side of the box. Tape measure revealed the top of the robot was less than 28" wide.
Unread 14-01-2009, 10:32
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Having been a robot inspector in the past, I found that the temperature of the venue changes the size of the box. When we started, one cold morning, the box was just a little bit small (more for the vertical measurement than the horizontal measurement) but as it warmed up, it grew. Something to keep in mind. Also, since the boxes are made at one temperature, and used (probably) in another, it is best to make it smaller so you will not run into these issues.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
Unread 14-01-2009, 10:35
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
We try to design for 27 x 37 as well. We learned the hard when we designed it to be 27.5 x 37.7 three years ago and we were grinding down bolt heads the day before ship in order to make the robot fit the starting dimensions. We also try to make the top a little less than 60 inches high, because there are lots of times when you fiddle with the mounting of the drive train and you REALLY don't want to have to hack off something vital at the last minute in order to make your robot short enough.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
[OCCRA]: Strain Relief Bolt Silent_Stryker OCCRA Q&A 1 25-10-2006 10:33
Bolt hole circle without a mill sanddrag Technical Discussion 12 01-06-2006 14:57
Bolt Action GateRunner Chit-Chat 1 15-04-2003 11:36
Goal Bolt Lengths archiver 2001 3 23-06-2002 23:14
bolt hole locations--Bosch and FP ajlapp Technical Discussion 6 28-10-2001 12:14
