Go to Post We'll defenestrate our programmer, and I'll report back our solution if we get anything working. - Nick Seidl [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 14-01-2009, 13:28
compuwiz12 compuwiz12 is offline
FRC #0386 (Team Voltage)
compuwiz12 is an unknown quantity at this point
wifi?
will we be able to have wifi networks up this year? Our scouting database uses one. Will we have to go wired?
Unread 14-01-2009, 15:19
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: wifi?
As far as I know wireless communications have never been allowed and is probably stronger this year due to the use of using WiFi routers and such.
-Tanner
Unread 15-01-2009, 01:07
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: wifi?
-Tanner
I have never heard of such a rule. Our team has set up a wireless router several times. I looked through the rules as well and I didn't see anything against it. Unless someone has found a rule (and if you have please post it) then I'm sure its perfectly fine. It shouldn't interfere with the robot radios during competition. This also may depend on the venue, I'm sure the venue can restrict you. (Actually at our regional there is usually free wifi available)
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 15-01-2009, 01:24
JamesByrne's Avatar
JamesByrne JamesByrne is offline
FRC #0360 (The revelution)
JamesByrne is on a distinguished road
Re: wifi?
My guess is this is one of the reasons they chose wireless n and not wireless g. The 2 should not interfere. Some of the venues have wifi that will not uninstall them just for first. So i think they had to make a system that will work around what alot of places already have.
The long ans short of it is i would ask in the q&a to be sure but according to what is published now i think that it will be allowed. Also I do not think they would have a reason to ban them.
Let me know if we find anything official.
Unread 15-01-2009, 01:42
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
Re: wifi?
More specifically, it seems that they're using the 5GHz band for Wireless-n. If they were using the 2.4GHz band, it would actually interfere _more_ with wireless G, due to the wider frequency use (which helps N signals get their advantages).
I'd say they chose 5GHz so that teams can still use 2.4GHz for Wifi systems, etc., especially considering many venues will have 2.4GHz band Wifi installed already, and would possibly cause interference. Not to mention that the 2.4GHz generally has a ton of interference in its vicinity from untold numbers of electronics (Bluetooth, etc.).
Of course, I'd still check. There were rules from previous years on this, and I believe there's a rule on using such wireless equipment, at least, in the arena. Don't quote me on that, of course.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 19-01-2009, 15:45
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: wifi?
As far as I know, FIRST discouraged WiFi, but as stated already, they can't stop venues which already use wireless internet. Buckeye, at least the two years I've been going, has allowed wireless, and you could usually find multiple networks during the competition, including 1676's famous scouting network. I've heard that some regionals completely disallow wireless at their venue in the past. This year may be different with the new control system, but I'll be watching Q&A, and have a plan for wireless and non-wireless scouting methods.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
[IMG] code is Off
interfacing via wifi? ratcateme FRC Control System 7 19-08-2008 02:28
St Louis Wifi addictedMax Chit-Chat 1 28-02-2007 22:31
Wifi on Robots mogunus Programming 9 08-03-2006 07:30
Wifi Networks Eugenia Gabrielov Chit-Chat 4 17-06-2004 09:56
wifi at nats Alexander McGee Championship Event 7 14-04-2004 23:38
