Go to Post I blame FIRST for everything good that has happened to me. - Herodotus [more]
Unread 14-01-2009, 13:04
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Shooter vs Dumper Trade Study
So what are the pros and cons of either design and why is one better than the other?
I'll start:
To me, shooting assumes you can't get to a trailer to score and you need to score from a distance (I guess because of the limited drive capabilities). But having 3 trailers to score in seems like there will always be one nearby. Also shooting seems like it will take too long and have more chances for jamming. Also in Aim High hitting a stationary target was hard enough, so how do you hit a smaller moving target with non-uniform objects (broken balls) consistently?
A dumper assumes you can get up close to a trailer, scores all at once and less mechanisms to jam. Doesn't care about ball shape.
I realize there's hybrids but ultimately it seems you still fall into one of these categories. Yes/No?
www.179swampthing.org
Unread 14-01-2009, 13:13
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Re: Shooter vs Dumper Trade Study
I personally think that effective dumpers will score a majority of the points and dominate the game. Unless you have a shooter like Wildstang in 2006 of course.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 14-01-2009, 13:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
A short range turreted shooter will allow you to score when you are close to the goal, and from either side of your robot. A dumper probably requires you to be lined up and right next to the goal. Since the goals will probably be driving away from you, using the finest evasive maneuvering techniques, you'd have to be really lucky to be able to dump a load of balls in a functioning robot's trailer.
Unread 14-01-2009, 13:35
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
There are times during game play where a dump is very viable..and easy.
When another team is unloading into the airlock, the trailer is stationary.
When another team is at the outpost getting the empty cell, the trailer is stationary.
When another team is pushed up against a wall by two robots, the trailer is stationary.
A dumping bot of sorts only needs to get to a trailer goal once or twice in a match to make a big difference.
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 14-01-2009, 13:38
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
[quote=Swampdude;800801]So what are the pros and cons of either design and why is one better than the other?QUOTE]
So why not build something that does both effectively?
Unread 14-01-2009, 13:44
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
How about a shooting dumper??
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 14-01-2009, 13:50
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Advantage to a shooter is that presumably, it can act as a dumper simply by slowing the spinning of its power mechanism (wheels, etc).
Based on our tests so far, it appears that tracking and auto-targeting opponent's trailers' is possible:
-We successfully wrote code that can distinguish an opponent's trailer
-The same code can give you distance and heading information within a few % points of the true value.
-By tracking the change in distance and heading, you can determine both the position and velocity of an opposing team's trailer, and thus lead it by an appropriate amount.
But:
-The enemy trailer will pretty much never be moving at a constant velocity
-There appears to be fairly substantial slowdowns in the camera code. It's not really real-time, more like 500ms-behind-real-time. We don't know how much this can be fixed, that'll be tonight's meeting's topic.
-The balls are irregular, and will become even more irregular as regionals proceed. Thus, muzzle velocities will be unpredictable.
-'Camping' and shooting will not be effective: you'll be a sitting duck for dumpers. Handling the accelerations that your robot is undergoing as well as the accelerations of your target will make your shooting much less accurate
When we were doing our original analysis, we essentially decided that shooters will have more opportunities to score, but will convert fewer of those opportunities into actual points.
Unread 14-01-2009, 13:51
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
In my opinion a shooter robot will be more reliable than a dumper robot.
While a dumper robot can score massive points when given the opportunity, it is relying on the mistakes from the opposing alliance to be able to make a dump.
A robot with a shooter will need to use the camera to track the trailers to be a threat. If the camera is used successfully and the shooter is geared correctly so it can score a lot of balls very quickly, then it will dominate.
I think the combination of a good shooter and a good dumper in an alliance will be very powerful.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 14-01-2009, 13:54
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
There is a hybrid option that really doesn't fall into these two categories though. A shooter doesn't have to use a turret and camera (and may not want to since it restricts you to one ball at a time), but could instead pursue a similar strategy to a dumper of getting close to an opponent's goal and unloading a large amount of balls into it. Being a shooter allows you to power the balls (instead of relying on a gravity dump) and gives you a few foot range rather than requiring your robot to be right next to the opponent.
Unread 14-01-2009, 13:55
O-H
FRC #0048 (Delphi E.L.I.T.E.)
How about a turreted shooting dumper?
Unread 14-01-2009, 14:03
Brandon Holley's Avatar
Bingo.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 14-01-2009, 14:08
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Originally Posted by Bongle View Post
But:
The low friction and thus low acceleration minimizes the effect of these problems.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 14-01-2009, 14:34
Mr B's Avatar
Mr B Mr B is offline
AKA: Andy Bradley
FRC #0233 (The Pink Team)
Mr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to all
It seems to me that the biggest constraint of dumping balls into a goal is the size limit of the robot <R11>. Without being able to exceed the perimeter, dumpers would have to be right next to a goal and be relatively unmolested to score a high percentage of balls. Still, a team that figures out a way to dump a load reliably and fast would be a force.
Bongle's Avatar
If your shooter has a moderate speed (8ft/s), then a robot just 10ft away could accelerate hard enough to be 1.5ft away from where you expected it to be (if you assume constant velocity). If you add in the inevitable imprecision of an orbit-ball shooter, the amount of balls you'd get in would be low.
A powered dumper seems to be the way to go.
Unread 14-01-2009, 15:11
RoboGeek99's Avatar
RoboGeek99 RoboGeek99 is offline
FRC #2582 (Panther Bots)
RoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really nice
I'll start:
Well the way you phrased it...it sounds like ur really kinda biased toward a dumping mechanism...here is my take on the matter not my team's
Shooter
Pros:Fast, Unlimited Range (Close or Far), Reliable
Cons:May be inacurate, requires a lot of practice, complex
Dumper
Prosrop all at once, accurate is used correctly
Cons:Needs to stay in the 28*38, needs to be right next to the opponent's trailer
I might forgotten something but after looking at all of these as unbiased as possible im leaning toward going with a shooter mechanism (thinking of a softball/tennis ball shooter powered by globes and an archimedes screw or conveyor system to get the balls in place)
Either way yall go good luck!
"Imagination is more important than Knowledge"-Albert Einstein
Love, Peace, and Robot Grease
2008-Lone Star Regional-Rookie Inspiration Award
2008-Lone Star Regional-2nd Place Winners w/ 118 Robonauts & 501 Power Knights
Defensive/dumper hall of fame Cody Carey Robot Showcase 80 11-03-2007 18:44
Poll: Dumper effectiveness at Championship The Lucas Championship Event 3 23-04-2006 00:33
pic: new dumper supersy77 Robot Showcase 2 11-04-2005 15:17
Ball Dumper Plans JDRobotics General Forum 6 22-01-2004 17:38
Anthropology Study Redhead Jokes General Forum 0 22-01-2004 13:56
