Go to Post Maybe FIRST will just take 148's Tumbleweed and use it as the game piece for next year. - AndyB [more]
Unread 13-01-2009, 19:50
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
WindRiver Errors
I compiled the layout given here:
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	RobotDemo(void)
		// put initialization code here
	void Autonomous(void)
		// put autonomous code here
	void OperatorControl(void)
	 	// put operator control code here
START_ROBOT_CLASS(RobotDemo);
and I am getting the following error:
C:\DOCUME~1\LCHS\LOCALS~1\Temp\make2565.sh: gcc: command not found
C:\WindRiver\workbench-3.0\x86-win32\bin\make.exe: *** [09_2429_v1/Debug/Objects/09_2429_v1/h/tool/common/defs.o] Error 127
Build Failed in Project '09_2429_v1' (Process Exit Value was 2):   2009-01-13 16:31:42   (Elapsed Time: 00:03)
What do I need to do to fix this, I dragged in the h folder and lib from the target folder, but its still not working, any suggestions?
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 14-01-2009, 09:36
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Re: WindRiver Errors
We are really stuck can no one help?
Ben Kellogg
Unread 14-01-2009, 10:05
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
gcc is the GNU C Compiler.
It appears that WindRiver can't find the compiler that it is set to use. If you poke around in the compiler settings, maybe you can find a place to set a path to the compiler. If you don't know where the compiler is, you can do a search (winKey + f) for gcc to try and find it.
Unread 14-01-2009, 10:11
foemill's Avatar
foemill foemill is offline
What do you mean it's overweight?
AKA: Eric Miller
FRC #1270 (Red Dragons)
foemill is on a distinguished road
gcc is the GNU compiler used by the make process to compile your code. WindRiver obviously can't find it to run it. Make sure that gcc.exe exists on your system, then check your path statement in Windows. It should include the location of gcc.
This all should have been handled by the WindRiver installation. I would hate for you to resort to a re-install but if your installation got hosed you may need to do just that. You'll save time in the long run.
#include "WPILib.h"
	RobotDemo(void)
Unread 14-01-2009, 14:49
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay for some reason I am now having trouble making a project, are there directions on making a project that isl inked to the compiler, because the read me files in the docs folder under the WindRiver folder are not helpful.
Ben Kellogg
Unread 14-01-2009, 15:06
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
also once the project is made how do you make a file in it, we are really confused, so any and all info on making this initial project, files ect.. would be extremely helpful!
Ben Kellogg
Unread 14-01-2009, 15:21
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Have you tried
File -> New -> Example
Then vxworks Downloadable kernel module sample project
Then select a template that starts with FRC?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 04-03-2009, 20:32
1308 1308 is offline
FRC #1308
1308 is an unknown quantity at this point
Unhappy Re: WindRiver Errors
Hi I am having the same problem as ExarKun666. I even tried re-installing and I still get that error. I don't know what to do now.
Windriver LAC McGurky C/C++ 12 25-02-2009 18:38
WindRiver WPILib problems Dr Nick C/C++ 5 13-01-2009 16:17
compiling in windriver koreabell Programming 4 05-01-2009 15:32
windriver projects nickmagus Programming 4 01-12-2008 23:29
