Go to Post Competing at multiple regionals or Championship events has no bearing on the life lessons you will learn or the unbelievable memories you will have--for that is what FIRST is truly all about. - Alivia [more]
Thread Tools Rating: Thread Rating: 6 votes, 4.50 average. Display Modes
Unread 14-01-2009, 15:43
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
void* pointer to object in C++
I have been at this for some time now, and this won't compile:
(function(int data))
void * MyPointer
if (data=0)
     Gyro gy(1);
     MyPointer = &gy;
if (data=1)
     Ultrasonic gy(1);
     MyPointer = &gy;
if (etc...
etc...
(function2(int data2))
if (data2=0)
     return MyPointer->GetValue(); //this produces error: 'void*' is not a pointer-to-object type (:eek:)
etc...
You can probably see what i am doing, (accessing different function based on sensor type), and Nothing has worked
Unread 14-01-2009, 15:51
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: void* pointer to object in C++
Don't use a void pointer, use a pointer to the base class. So for those I think its SensorBase.
Unread 14-01-2009, 15:58
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
To be in line with the strictest and most proper C++ design principles (a very good idea), you don't want to use void* in the scenario you describe. Rather, you want to take advantage of polymorphism and use an abstract base class pointer instead.
For example, if all your sensors derive from a single abstract base class (like the WPILib classes do), then you can use a pointer to the base class to access the inherited class functions.
I assume that GetValue is inherited from SensorBase and is virtual. ( I don't have the library in front of me at the moment.) Therefore, rather than using a void* you can use a SensorBase* like this:
Gyro gy(1);
Ultrasound us(2);
SensorBase* mySensor;
mySensor = &gy;
mySensor->GetValue(); //mySensor calls Gyro::GetValue() here
mySensor = &us;
mySensor->GetValue();//mySensor calls Ultrasound::GetValue() here
If you want to use the void* you need to recast it for the compiler to know what you are doing. So, you need a recast for each different sensor. This leads to all sorts of extra code that you avoid by going the polymorphic route.
-Jeff Erickson, FRC 41
Unread 14-01-2009, 15:59
byteit101's Avatar
Thanks! I'll Try that!
Unread 14-01-2009, 16:28
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
And for future reference, void pointers need to be casted to the correct pointer type in order to be used. This should fix your error.
Unread 14-01-2009, 16:41
byteit101's Avatar
like (Gyro)MyPointer->GetValue();?
or ((Gyro)MyPointer)->GetValue();?
or ((Gyro)(*MyPointer))->GetValue();?
Unread 14-01-2009, 17:15
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
None of the above.
Your pointer is the wrong type. So it's the pointer you have to cast to the correct type of pointer:
((Gyro *)MyPointer)->GetValue()
But you don't want to do this Do as suggested in the prior posts as it is much cleaner and less error-prone.
Aiming that remote: Laser pointer allowed? efoote868 Rules/Strategy 9 02-03-2008 21:01
Pointer to pwm bronxbomber92 Programming 5 07-02-2008 15:57
Suspicious pointer conversion ebowla Programming 2 26-01-2008 12:13
laser pointer 1574aviad Technical Discussion 9 20-02-2005 20:25
problem with void Process_Data_From_Local_IO CmptrGk Programming 2 29-01-2005 17:14
