Go to Post When we stop asking ourselves the hard questions, whether as team leaders or in life, then we are failing. - Al Skierkiewicz [more]
Unread 14-01-2009, 15:58
M. Gildner's Avatar
M. Gildner M. Gildner is offline
College Mentor
AKA: Matt
FRC #2620 (Servos)
M. Gildner is on a distinguished road
Question RPM of Fisher Price gearbox
What is the RPM of the Fisher Price gearbox using the FP motor.
I have the rpm of the motor, but cant find it for the gearbox and i dont know how to figure it out. Any numbers or suggestions on where to look are welcome.
Thanks for your time and help
2620
Unread 14-01-2009, 16:37
Re: RPM of Fisher Price gearbox
2620
This has been discussed recently, but here's the "simple" way: figure out the reduction of the gearbox.
Let's say, as an example, that you have a motor that turns at 10,000 RPM and you have a 2:1 gearbox. This means that for every 2 turns of the input gear, the output gear turns once. Your output RPM is 5,000.
Now, a stock FP gearbox is about a 124:1 reduction. So, for every 124 turns going in, 1 turn comes out.
If you want to check the numbers, you can always open up the gearbox and count teeth. This will give the ratios for each set. Multiply to get the final. (This due to the fact that every gearset affects the next one down.)
Unread 14-01-2009, 16:44
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
I don't have numbers for this years FP motor but the gearbox is 124:1 according to the JVN design calculater. Past FP motors have spun at about 16k rpm so if you divide 16000 by 124 you get about 130 rpm if there is NO LOAD. With all them gears and friction in the gearbox I would estimate more like 110-120 rpm on the output side. Of course, you could always use a watch and count how many turns in 10 seconds and multiply by 6. Just put a popsicle stick in between the prongs and count away.
Bruce
Unread 14-01-2009, 19:39
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Remember that this year's F-P comes with a 16-tooth pinion, not 19. So the data given above regarding the gearbox ratio might not be appropriate, since it's probably based on the 19-tooth version that we've been receiving for several years.
You might want to have a look inside (and let us know what you discover).
Unread 14-01-2009, 19:53
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
On Monday we pulled apart one of this years FP gearboxes to see if the gear sizes were different than before. I didn't check all of the gears (only the useful ones), but the first two stages were exactly the same as the ones in the 19 tooth gearbox. I think the internals of the new gearbox are all exactly the same except for the motor pinion, but someone should check to make sure.
Fisher Price Gearbox? excel2474 Technical Discussion 10 12-01-2009 21:14
Fisher Price Gearbox nreynolds General Forum 23 22-01-2008 13:18
Fisher Price gearbox Manoel Motors 0 14-02-2003 16:06
How Many RPM does a Fisher-Price Motor Spin At? archiver 2000 7 23-06-2002 23:22
Fisher Price Gearbox Q... Anton Abaya Motors 17 27-01-2002 08:39
