Go to Post There's no finer engineering than pit engineering. - kaszeta [more]
Unread 13-01-2009, 17:20
Fish2977's Avatar
Fish2977 Fish2977 is offline
Biscuit Team Leader
AKA: Butcher Pete
FRC #2977
Fish2977 is an unknown quantity at this point
Error
Our team is new this year and while tring to connect to the CRIO we got this error: Error -63192 occurred at _nirio_device_open.vi:1 we are getting very frustrated and have no mentor, help?
Unread 13-01-2009, 17:49
Fish2977's Avatar
Biscuit Team Leader
AKA: Butcher Pete
FRC #2977
Re: Error
yeah
Better be Bonzo.
Unread 13-01-2009, 18:00
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Error
It sounds like a generic communications error. When you say you're trying to connect to the cRIO, are you trying to connect to it to update the firmware on it, or to download code to it?
Unread 13-01-2009, 19:32
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Re: Error
I'll have to admit, I have never seen that error before but, if you haven't already, reboot the cRIO, ping it and if you get a reply, try again. if after that it still doesn't work and you get a reply, log onto it directly by typing it's IP adress into your adress bar (10.29.77.2) and diagnose it from there.
Unread 14-01-2009, 16:32
Fish2977's Avatar
Biscuit Team Leader
AKA: Butcher Pete
FRC #2977
Exclamation Re: Error
We are trying to upload code, only example codes from the Lab View work, so we do know that we have connection, and we have made our own programs and they work on our robot. Then a couple of days later the program wilol get an error?!?!?!?
Better be Bonzo.
Unread 14-01-2009, 16:43
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Error
Are you in Windriver and using C++? if so, you need to re-image the cRIO before switching between LV and C++
Unread 14-01-2009, 16:48
Fish2977's Avatar
Biscuit Team Leader
AKA: Butcher Pete
FRC #2977
Re: Error
No were just using Lab View
Better be Bonzo.
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
