Go to Post I guess I'm a bit of an apple fanatic. - Austin [more]
Unread 14-01-2009, 17:34
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
paper: Reading the FTC Battery Voltage
Thread created automatically to discuss a document in CD-Media.
Reading the FTC Battery Voltage by PhilBot
Unread 14-01-2009, 17:36
ringo115 ringo115 is offline
FRC #1647
ringo115 is on a distinguished road
Re: paper: Reading the FTC Battery Voltage
Philbot, ive been racking my brain for the past few hours trying to figure out about the NXT items you have in the battery display, where can i find those items, all i have is question marks, please write back ASAP
Unread 14-01-2009, 19:49
PhilBot's Avatar
AKA: Phil Malone
OK, I'm going to assume you are working with FTC (not FRC), and if so, you should have downloaded a bunch of "FTC" vi's to augment your copy of LabVIEW.
These are in addition to what you got when you did the initial FTC LabVIEW install.
Most of these VI's are used to access the Motor Control Encoders (or encoder related functions). They are part of the "FTC Toolkit".
The update is referenced on the FIRST FTC page:
http://www.usfirst.org/community/ftc...t.aspx?id=6650
Go to this page in the NI site to see the available updates:
http://zone.ni.com/devzone/cda/tut/p/id/7956
In particular is this update page:
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1129
You want the update file called:
lv_ftc_motors_nov1708.zip
After downloading, you must follow the direction at the bottom of the page to install them. It requires you to unzip the files and copy them to a folder contained in the LabVIEW program folder.
c:\program files\LabVIEW 8.5\vi.lib\addons\FTC Toolkit
This should now give you a new sub-pallette called "FTC Motor Encoder Functions"
That's where all the controls are that I use as part of my control.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 15-01-2009, 15:17
FRC #1647
ok, well im actually in FRC, do you know if theres any compatibility there
Unread 16-01-2009, 08:46
PhilBot's Avatar
AKA: Phil Malone
None.
To read voltage in FRC you just need to read the analog voltage on chan 8 slot1 and convert to volts (scale by 1.68)
See how they do it to send to driver station.
Phil Malone
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
[FTC]: [FTC]: Replacing Fuse for Battery fqzeng FIRST Tech Challenge 4 18-11-2008 20:04
The 8.2 (or 8.3) Battery Voltage Bug eugenebrooks Programming 167 21-02-2008 20:05
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
