Go to Post I have never before seen the words "smaller" and "Saturn V" used in the same sentence. Wow. :yikes: - DonRotolo [more]
Unread 14-01-2009, 20:59
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question code interface node in LabView
does anyone know how to make the code interface node work in LabView? Supposedly you can use this VI to input your own programming code, such as a .c source file. We are trying to figure out how to make this work but can't figure out how. If anyone knows help would be greatly appreciated.
Thanks
be prepared for the unexpected
Unread 14-01-2009, 21:13
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Re: code interface node in LabView
I got the code interface node running and am successfully running a mixed mode on our bot. Our autonomous is in C++ and our telop is in LabView. Use this tutorial:
http://zone.ni.com/devzone/cda/tut/p/id/5694
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
Unread 14-01-2009, 22:57
The code interface node is actually a pretty old feature, and if I'm not mistaken, it is not present on the cRIO PPC. The node for calling C/C++ code from LV is the Call Library Interface node. If you are just getting started, see how far the tutorials get you. If you have specific questions, I'll be glad to give a hand.
Greg McKaskle
Labview: Feedback node doesn't reset on "stop" kamocat NI LabVIEW 10 09-06-2016 23:43
Code::Blocks IDE interface (Tutorial/Makefile) Cjmovie Programming 8 25-01-2008 02:18
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Operator Interface code RiotingNerd Programming 5 07-02-2004 21:13
