Go to Post Maybe this thread should be re-titled "Waiting impatiently for the 2011 hint!" since having over 100 posts doesn't seem very patient. - Joe Ross [more]
Unread 14-01-2009, 23:42
Re: Driver Station Update
The dongle problem is probably just a fault in that little switch on it.
If you have a multi-meter try testing the pins while you flip the switch to see if it's operating properly.
The motors not running is probably a separate problem.
How far did you get in your setup?
Did you bench test the control system?
After that did you reflash the cRIO and the Driver Station?
Were you able to set your team number on the DS?
Is your DS plugged directly into the cRIO with an ethernet cable or are you using the wireless?
Has the wireless router/bridge been setup?
driver station firmware update bobbyt14 Programming 15 14-02-2009 15:05
Driver Station firmware update failure ofshea FRC Control System 8 13-01-2009 11:35
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
