Go to Post What are you people going to rumor mill about if we ever actually get a water game? - Kevin Sevcik [more]
Unread 14-01-2009, 19:48
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Driver Station Update
We are having a problem with setting up. We did the update and held the down button after for a while, and it still didn't work, so we unplugged it, and re-plugged it in, and waited 2 min b4 doing anything, and tried again, but we were unsuccesful, then we discoverd are dongle switch won't switch from enabled to disabled. What do we do to fix this, can we reset completly? Any suggestions?
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 14-01-2009, 23:08
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Re: Driver Station Update
We are really stuck can anyone help plz?
Ben Kellogg
Unread 14-01-2009, 23:20
So I'm guessing you can't set your team number on the DS?
What is displayed on the DS screen on the bottom line?
As far as the dongle goes - does the DS screen say "Enabled?"
And you can't get it to say "Disabled?" Even when you completely disconnect the dongle from the Ds altogether?
Unread 14-01-2009, 23:28
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
I don't have the DS with me at the moment so as soon as I get my hands on it I can type up what it is giving me, but I know for sure about the dongle, when you disconnect it and you flip it up (enabled) and plug it in it will say enabled, but the motors don't run, and when you flip the switch down(disabled), without unplugging it in, the DS still says enabled. When you unhook it, and re-hook it with the switch down it says disabled, but when the you try flipping the switch up it doesn't say enabled, and the motors don't work in this case either. If you need to know the DS screen, and what it is saying to fix this problem too, just look here tomorrow, and I will have it up.
Ben Kellogg
Unread 14-01-2009, 23:42
The dongle problem is probably just a fault in that little switch on it.
If you have a multi-meter try testing the pins while you flip the switch to see if it's operating properly.
The motors not running is probably a separate problem.
How far did you get in your setup?
Did you bench test the control system?
After that did you reflash the cRIO and the Driver Station?
Were you able to set your team number on the DS?
Is your DS plugged directly into the cRIO with an ethernet cable or are you using the wireless?
Has the wireless router/bridge been setup?
Unread 15-01-2009, 01:58
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
We have it all up except the team number thing.
We tested the entire control system, motors, and everything worked, up until the point where we tried to change the team number
I'll see tomorrow
Direct link with ethernet cable to cRIO
wireless has been setup
Ben Kellogg
Unread 15-01-2009, 10:25
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay this is what the display says on the DS:
Team : 0000
Mode : Teleoperated
System : Enabled
Battery: No Comms
DS Rev: 2008-10-29a
Right now the dongle switch is up though, if I restart it with it down instead of enabled it wil say disabled, so is there any other info you need, or what is the problem? TY For all the help!
Ben Kellogg
Unread 15-01-2009, 10:34
On the DS push and hold the "up" arrow button for what seems like a minute.
Unread 15-01-2009, 10:39
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
TY SOOOO much it worked!!! TY for all the help!
Ben Kellogg
driver station firmware update bobbyt14 Programming 15 14-02-2009 15:05
Driver Station firmware update failure ofshea FRC Control System 8 13-01-2009 11:35
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
